Question about Kenmore 62702 Microwave Oven
Microwave Oven completely dead
After boiling water on the stove for a few hours trying to humidify the air in the kitchen the microwave went out. No lights on the key pad, no anything. I let it dry out for a few days even put a fan blowing on it and replaced the 250v 20amp fuse. Still no luck, when I plug it in there is nothing. The outlet I am using to plug in the microwave is providing power.
  • Anonymous Nov 08, 2007
    I replaced 20 amp fuse after microwave went dead.Display powered up and I attempted to set time of day and pushed start button when appliance died again.
  • Anonymous Mar 29, 2014
    i used the microwave to boil water and then tried to use it 5 minutes later but it would not work; it acts as if it isn't getting power but when I plugged it into a different outlet, still not working
  • Kenmore Master
  • 9,156 Answers
I sure hope the hood fan was on... It should always be on whenever you're boiling on the stove top, otherwise moisture can get into the microwave controls. The typical microwave will have just one power line fuse and two thermal fuses and/or thermostats, and the failure of any one of these can render the oven "dead". One thermostat / thermal cutout will be on or near the magnetron and one will be on top of the chassis / cavity. Does the inside light come on when you open the door? If so, then it's probably a problem in the control unit. If not, then it may be a bad thermostat or thermal cutout but it may still be the control unit. We have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You may find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 or http://www3.sears.com If you think it's a problem with the control panel, we repair those for $32.50 nationwide in most cases. Full info is available via our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Feb 22, 2007
    Problem Solver:
  • 16 Answers
Check if there's a fuse on the front panel.i'f had it on other makes.replace fuse and it should be ok.
SOURCE:
I have a Magic Chef microwave MCO160UB. I was cooking on the stove (microwave wasn't on) and the fan came on as it has done before. After a few minutes, it shut off and is now completely dead. I...
If the microwave is above the stove, the heat sensors in the microwave
may turn on fans to cool it even though the microwave itself is not
running. It tries to save its life. It should turn off when the stove is not
heating it.
Aug 29, 2011 | Magic Chef MCO160UB Microwave Oven
Boiled and egg and killed the microwave. Any way to revive it?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ii
Apr 03, 2010 | Sharp R-320HQ Microwave Oven
Boiled water and it exploded, now the microwave is broken
wow, from the looks of it you need to unplug wait 60 seconds plug in to restart, ot buy a new microwave. Perhaps if in the microwave terms it didn't say not to do that call the manufacturer and the will replace it for free
Jul 03, 2009 | Maytag MMV5000 Microwave Oven
My maytag over the oven microwave just died;
most likely the power supply in the microwave is gone. the microwave die probably it is over the oven. heat from the stove cause the microwave to heat up and cold off more than it is on the counter.
counter microwave has fan and air slot in the rear. it keep the motor and microwave cool, and there nothing else to keep it hot. but the over the oven, the only ventalation is from the top. and with the added heat from the stove top and oven.
Apr 27, 2009 | Maytag MMV4205 Microwave Oven
I have an over the stove kitchenaid microwave w exhaust hood. About 1/2 hour after boiling water on my stove, my microwave comes on. I have unplugged the microwave-----any ideas?
The issue is probably your exhaust fan on your microwave comes on automatically when it detects a certain temperature. Mine does this as well but will turn off automatically after temperature goes down.
Feb 25, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Bosch microwave HME9750
the sighn with a spoon inside is to alert you to the dangers of delayed boiling this is were the liquid in a container is heated on the outside quicker than the inside when you remove the liquid and expose it to the ambient air in your kitchen the liquid can boil over scalding your hand it doesnt have anything to do with your friends cup of tea this is pure coincidence the pop is the internal safety fuse blowing will need attn from service tech to sort high voltage safety fuse blowing means inverter or mag faults.
Aug 07, 2008 | Bosch HME9760 Microwave Oven
Dead Microwave Oven
Remove the top cover of oven, there should be tec screws on the bottem of unit to remove the cover, check for bad relays,fuses and fuseable links that could have finaly gone bad.
Jan 13, 2008 | Maytag MMV4205 Microwave Oven
Kenmore 62702 Microwave Oven Logo
377 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
