Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper jambs in the feed. The right side seems to pull down first then just jambs up.
    Scholar:
  • 162 Answers
Solution: Remove foreign objects from Rear Tray MP210
Remove foreign objects from Rear Tray When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
  1. Power the printer off.
  2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note : After confirming that the scanning unit support < 1 > is fixed into position, release your hands.
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
  1. Close the scanning unit (printer cover).
    Caution: Be careful not to pinch fingers when closing the cover.
  2. Power the printer on and confirm that the printer operates normally.
    Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
And
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  1. Remove all sheets of paper from the rear tray, then click 'OK'.
  2. Confirm the following message, and click 'OK'.
  1. Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
6efb7a7.jpg After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
Paper jambs - 4c2ebb0.jpgg src="http://i.fixya.net/uploads/images/4c2ebb0.jpg" alt="4c2ebb0.jpg" class="h_mi" />
Confirm the following message, and clickPaper jambs - be0716b.jpg>
Note: The following message is displayed when the papePaper jambs - 8231ebf.jpgd ejected.
  1. Click 'OK'.
Roller Cleaning is completed.
Cyber Kaka
Posted on Dec 08, 2008
Printer jams when duplexing
Most printer jambs are caused by a couple of things. Have you tried different paper? Sometimes paper that is curled, or if the humidity is too low, the paper will hold a static charge and cause paper feed problems. The other is worn or dirty feed rollers, try cleaning the feed rollers with isopropyl (rubbing) alcohol.
Nov 02, 2014 | Canon Imageclass D420 All-in-one Laser...
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
I have a dell 1720dn printer and the paper is getting stuck at the back of the printer as is coming up out of the printer. It looks like the right side of the printed page is smudged and the paper is also...
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky andcauses the paper to not feed straight.
Aug 31, 2011 | Dell 1720dn Laser Printer
Printer will not feed paper straight grabs one side and pulls the paper crooked and crumples the paper
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Aug 07, 2011 | Dell 922 All-In-One InkJet Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I am using Canon Pixma MP145. Paper gets jammed every time i want to print. Paper gets pulled in only from right side and it gets jammed, but printer does't show any error. I have to pull the paper...
Jul 14, 2011 | Office Equipment & Supplies
Paper will not feed, goes in crooked. gets caught on right side
Jul 07, 2011 | Dell 725 InkJet Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
EPSON STYLUS PHOTO RX425, PAPER PROBLEM
disconnect the printer from the computer:
>manually feed paper using the paper feed button.
>observe, if the printer pulls only one side of the paper then it´s a hardware issue
Jan 01, 2008 | Office Equipment & Supplies
Canon PIXMA MP210 Photo All-In-One Printer Logo
300 people viewed this question
old marine
old marine
