Problem for Printers
Generic problem for all Printers
HP DESKJET 3820
GREEN LIGHT FLASHING,
HP DESKJET 3820
GREEN LIGHT FLASHING, WILL NOT PRINT.
Solution #1
posted on Dec 08, 2008
Rank: Wiz
Rating: 82%, 116 votes
Issue
Printer cover is open
SolutionClose the cover.
Issue Printer is out of paper
SolutionInsert appropriate media in the In tray.
IssuePrinter has difficulty picking up label media
Solution
Change the printer's print mode setting.
Change the printer's paper type selection.
Use a different brand of label media.
IssueThere is a paper jam
SolutionFollow each of these steps until the problem is resolved:
Remove the paper from both paper trays.
Press the Power button once. Wait a moment for the paper jam to clear.
If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
Remove the rear access door.
Remove the paper jam through the opening at the back of the printer.
Replace the rear access door.
Reload the paper into the paper In tray.
Print the document.
IssueThere is a problem with a print cartridge
Remove and then reinsert the print cartridge(s) into the printer.
Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
Manually clean the print cartridges and print cartridge cradles:
Open the printer cover and wait until the carriage moves to the center.
Press the Power button to turn off the printer.
Disconnect power cord from the back of the printer.
Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
Lightly moisten a cotton swab with distilled water.
Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
Reinsert the print cartridges.
Close the printer cover.
Connect the power cord to the back of the printer.
- Press the Power button to turn on the printer.
Calibrate the print cartridges.
If the light is still flashing, replace the print cartridges.
IssueThe print cartridge has partial loss of electrical interface with the carriage connections
Solution
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
Cyber kaka
Solution #2
Rank: Guru
Rating: 88%, 166 votes
Here you will find some possible solutions to the issue you described.
Hope this helps. Please remember to rate this information.
Thanks
Popular Solutions for Printers
HP Officejet 4355 All-In-One InkJet Printer
2 Solutions
HP OfficeJet 6110 All-In-One InkJet Printer
1 Solution
Canon PIXMA MP160 All-In-One InkJet Printer
3 Solutions
Canon PIXMA MP150 All-In-One InkJet Printer
2 Solutions
Questions and Unsolved Problems for Printers
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a...
(More)
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a very old printer ?
Thanks
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not...
(More)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not necessary)for my home that at least does decent photos for my personal use. Any suggestions?
turn it on, beeps 3 times and power light flashes, print head comes to centre - it will not print
I have an ESP all in one printer with a paper jam. How do I open the or back to get to the paper to...
(More)
I have an ESP all in one printer with a paper jam. How do I open the or back to get to the paper to remove it. It is a small piece-I removed the rest already.
Got 3 computers on wireless network trying to access v505 via wireless connection. 2 work fine. 1...
(More)
Got 3 computers on wireless network trying to access v505 via wireless connection. 2 work fine. 1 doesn't via wireless or usb. Print Monitor hits 99% then freezes. Running XP Home SP3 on the nonresponsive computer. Oh, this is running in a dell 8250. Was with Dell for hours running uninstall and reinstall. Nothing worked. Any ideas?
