Need tp know how to connect the wires from power supply to everything else
  • Asdf hsdf May 11, 2010
    you want to change the smps power supply
  • 61 Answers
There would be a big connector with 20 pin connector thats a motherboard power source and the rest one with 4 wire connector are for the hdd and cd drive and there should be 4 pin connoter that goes to mother board
Regards
Samson Ved
Posted on Dec 08, 2008
Ii replaced all the parts in my percision analog power supply i dont know how tp reconect tbe wires can someone help me
I'm not sure what that is but I would probably go online to find the answer you will probably have to take it to a place where they know about these things or just DIY (do it yourself)online.
Apr 28, 2015 | Power Computers & Internet
I want to connect to BT broadband using my TP-Link TD-WD8901G routerg
Sounds like you need to change the TP link router for a wireless Access Point or a range extender.
Who knows what goofing around BT does with their equipment.
Mar 20, 2014 | TP-LINK TL-WR642G Router
In my device wirless strangth singal led is not power on. pls give me solution(TP-Link) TL-WA5210g
http://www.tp-link.com/en/support/downloadFiles.aspx?mid=01030301&version=V1&pmodel=TL-WA5210G
Seems a problem with the firmware. Double check if your product is the same as the link above and apply the fix described in the support page.
Top firmware version 09/30/2010. this firmware version will include the previous fixes like LED is not ON. Download the file decompress and execute. Please use a wired connection (CAT5/6 network cable) between your computer and the outdoor device. Do not use the wireless connection and be sure that both devices (source computer and destination AP/router/wireless TP device are powered up at mains (no batteries). Back-up yor settings as a firmware update is possible to erase all your settings.
A bit of trivia:
Your wireless outdoor device is decent but not "50km". For that you need a big comms tower.
Good luck.
Jun 29, 2011 | TP-LINK TPLink TLWA5210G 24GHz High Power...
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Need help! Cannot access YAHOO and FACEBOOK,Thru tp link wired router (TL-R402M). Hope you can help me with my problem. Thanks! Jun Santos
try power cycle by removing the power of the router for one minute then plug it again. check the cable if all of it tightly connected to the specified port if it is a modem router it should have a 3 cable connected to it Phone line, Ethernet cable and the power adapter. the Ethernet cable should be connect to the back of your tower( computer). check you phone for a dial tone. check the light in the router like dsl , ethernet ,internet and activity. all of these must have a light.
Apr 14, 2011 | TP-LINK TPLink 4port ADSL2 Wired Route...
I hooked everything up but it only turns on constantly i cant get it to turn of with the rest off the car
you need to know which wire is your constant (+) supply and which is the switcheable (+) Connect the yellow wire from the deck to the constant + and the red from the deck to the switcheable + power as the red is you on off and the yellow is your memory. Sounds like you almost have it right-just need to find a switcheable power supply for the red .
Dec 11, 2010 | Pioneer AVHP3200BT Car Video Player
Please help me out in connecting two wifi routers
Hi there! Follow these instructions:
Place your TP-Link at the center of your business location for wi-fi easy-access for your customers.
Then connect an 8-port Switcher (HUB) in one of the 4 ethernet ports at the back of your TP-Link so you can use them for your hard-wire connections.
On your TP-Link, you still has 3 ports available and your customers can also connect to your wireless network easily!
Get back to me if you need additional tips!
^_^
Apr 14, 2010 | Computers & Internet
Got a astec sa302-3505 power supply . . . need to know how do you add a switch to turn it on if its not connected to the motherboard
Simple, Just connect a switch to Green wire and one of black wire.
When the green wire got connected with negative (Black wires are negative) the SMPS Fan starts which is also a visual feedback to you that SMPS starts.
----------------------O /
Grean /
-----------------------O
Black
So simple..
Jan 26, 2010 | Astec 300w AT Power supply 190170-01...
Packard bell i need to reboot my pc tp wipe my hard drive of virus and restore everything to factory defult
put recovery or wincd disk in drive restart when screen says boot with cd click enter follow the steps
if can't boot from cd restart while continuosly pressing f7 startup options will appear high light cd or cd/dvd option
then should boot with cd
Jan 16, 2009 | Packard Bell (190169) Power Supply
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
