Question about Samsung Refrigerators
Hi, Ihave problem with mz freeyer inside fridge model RA21F/RA19V.I thing when I was clean freeyer I broked,is not coled,not ice and alsoo fridge not codl.I want asking zou if I can fixid freeyer and fredge or if I neede buz new.Thank you.
I take it your icebox has packed in following damage to it as a result of cleaning. Check for any cracks or loose pipe/connection. If it's there then you'll have to get it fixed. Check with any small electrical retailer if they can recommend an engineer. Phone him and explain the problem and he should give you an estimate for repair. If it's too much, then you can decide whether or not you want to pay that or put the money towards a new fridge complete with a years parts and labour guarantee. Stay with the small electrical shop as they have better after sales service.
Posted on Dec 08, 2008
Why is my sub zero fridge model 590 warming up?
Hi fridges will warm up on the outside as they remove heat from the inside. excessive heat with not extreme cooling inside the fridge indicates a possible degridation of coolant fluid or a leak. as the motor tries to cool the fridge the thermostat inside stays on as the tempreture inside has not been reached. if you hear the motor/ pump continually running this will indicate a cooling problem.
May 28, 2014 | Sub-Zero Refrigerators
Ihave changed the crank sensor and the coles on the plugs but still the it wont give a spark.
DID YOU CHECK THE COIL PACK.........THIS SENDS A SPARK TO YOUR SPARK PLUG
Apr 15, 2014 | 2005 Toyota RunX 160i
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
Hi,my bosch f/f is freezing in the veg box and has a lot of ice under the last box in the freezer comp.What is the problem please?
In the back of your fridge you should see a hosepipe connected from the freezer's defrost water drain to the evaporating tray usually located on top of the compressor. The drain is blocked, hence you get ice on the bottom of freezer. The easiest way to clean it is to pull the hose pipe off the fridge outlet and clean the drain upwards with a piece of soft wire or electric cord or something similar. On my fridge (Bosch) I found the drain clogged with a kind of jelly like stuff. The other way to the drain is by removing back panel inside the freezer compartment but be careful, I sort of ripped mine off and broke plastic plugs on which it was fixed. Make sure you know what you doing.
Cheers Karel
Jul 28, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
The refrigerator is dripping water at the bottom of the fridge. Everyday we walk by the fridge and see lots of water dripping from the fridge.
Hi, The defrost drain is plugged. Remove the rear panel inside the freezer section and locate the drain hole. Remove all the ice and flush the drain out with hot water to make sure it is open. Some models require an after market drain heater kit. If you will get me a model 3, I can look this up and let you know if you need the kit.
Vic
Jul 04, 2009 | Refrigerators
Ice dispenser will only dispense crushed ice
Ihave zannusi ZX99/5SI fridge freezer. Top-freezer compartment is not cooling. I have done as before, defrosted and cleaned both fridge and freezer but, with no luck. Freezer is working OK but top-fridge  is not cooling. Could you please help with advice in what to de next.
Thank you
GAZ
May 12, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Interior fridge fan continues to ice up
hello when you put the back panel to the refrigerator section back on did you notice that there was any stryofoam missing or broken on the cover? Had one do the exact same thing and what I found was that when the pevious person took the panel off the stryofoam some how broke and the air flow would bypass the coil causing it to freeze up after a while, also when I took it apart all of the screws were not in the cover further compounding the problem. I repaired and reassembled and it has been working great ever since.
Dec 26, 2008 | Freezers
I have a 8 year old amana fridge model #SQD23VE we had a power outage about 1 week ago and the fridge has not been cooling properly since i hear the fans running but no ice is being made and things are not...
hi thanks forr the question so you cleand the coils inside the freezer and at the back by the compressor and was the compressor running . if it was and still not cooling you have a compressor problem
Sep 26, 2008 | Refrigerators
Light is on but frig stopped cooling
I had a problem with my Viking where the light stayed on in side and was causing havoc with the coling system.
I saved 200.00 doing this.
get a cell phone or a small video camer place it inside the fridge and record to see if the light stays on when the door is closed.
If it does. You may just have a light switch to replace or like I did readjust the push spring that the door hinge hits to active the switch.
Once I did this the light went out and the fridge started cooling normally. the lights will heat up inside the fridge and screw up the thermostat. then the fridge will start to cycle. not good for the compressor.
hope this helped.
good luck
Jun 25, 2008 | Kenmore Refrigerators
Refrigerators Logo
51 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
