Question about Roper RAS6233KQ Top Load Washer
Help ! I have this washing machine that I just bought new two years ago and it is not draining out all the water completly which then becomes a very unpleasant smell when you open the lid. I noticed the tips for the problem I am having and I will check to make sure nothing is clogged the pump, like a sock from the little ones, but I still have a question - Is this a belt driven washing machine ?
  • spd0169 Oct 01, 2008
    When washing with my roper washer, the washer goes into the rinse cycle. When it gets to the point that it is supposed to drian, it stops. There is no noise, and it is like it wont switch to the next cycle.
    President:
  • 878 Answers
Jackson, this is a direct drive model, no belt, check out the attachment. Catriver..post back
Posted on Feb 22, 2007
Daewoo washer DWF 800WPS water drains before wash
Make sure the drain hose is about 1 metre high from ground. If drain hose is lower the water will keep draining.
May 27, 2013 | Washing Machines
Hello, i bought an LG front loader washing machine (WD 11020D)just 2 weeks back. After every 2-3 washes, the drain filter becomes full of water in a way that even water remains in the drum after the...
you may have a kinked drain hose so the water cannot drain out properly. or if you have the drain hose plumbed into your sink u bend the hole in the spigot may not be opened up large enough.
Aug 23, 2010 | LG Washing Machines
Machine clogged and rust and stink
to help clean the unit, do a large load of whites, extra bleach, extra-super-heavy-duty wash, hot wash and hot rinse. many small loads sometimes cause the unit to "smell up"
Sep 04, 2009 | LG WM2077CW XL Front Load Stackable Washer...
I have a Kenmore Elite washing machine-wont spin
remove the lower panel. it is held on with 3 1/4 inch headed screws. With a pail to catch the water, remove the clean out cover. Ifr the clean out is plugged, the washer will not drain.
Jul 25, 2009 | Kenmore Washing Machines
NOT DRAINING ALL THE WATER OUT AFTER A SPIN CYCLE
look for this part under your machine at www.repairclinic.com/SSPartDetail.aspx?s=t-LSR5132PQ-%3d%3di541811&PartID=541811 take it off and clean it out this is a washer lint catcher and when clogged will prevent the complete drain of your water.
Mar 14, 2009 | Whirlpool LSR5132PQ Top Load Washer
How do you diagnose a bad washer pump vs a cloged line?
Amana ALW480DAW seems to be not completely draining. When I start a new load water in basket becomes dingy and smells. Washer smells when it has not been used for a couple of days. We have checked the outflow and inflow drain tubes found no problems. It seems to spin and agitate normally, it drains to a point and leaves water in it, not visible in the basket. When we blow on the outflow tube when it is done draining there is still water present, we can hear it bubble.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Water won't drain won't spin Kenmore front loader
glad i could help.if you have a chance ,i thank you for you great rating
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore top loading washer 70 series
Hi I have a kenmore that is moving when it spins....some water left when spin is completed. We recently moved the machine to clearn behind it and this issue started. movement is about an inch per cycle.....can you help? thankse ,pde 22422
Dec 10, 2007 | Kenmore 22422 Top Load Washer
My washing doesn't smell clean? Help
the drain water pump its not working properly , needs to be cleaned the drain hose needs to be check for posible bent or clogged , ,please be sure that the drain hose ,and drain pipe are installed ,no more than 12 inches above .of the machine, and avoid long hoses. let me know thanks
Jun 20, 2007 | Whirlpool AWM5145/2 Front Load Washer
Roper RAS6233KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
