Question about HP Pavilion dv6000z Notebook
Ziener diode is zeiner diode works on forward biasing
    President:
  • 173 Answers
Yes, Zener diodes can work both on forward and reverse biasing. The primary difference between a zener diode and the ordinary junction diode is it is designed specifically to operate with a reverse bias voltage that is high enough to cause the the device to breakdown and conduct a high reverse current. Hope this answers your question and provides you with some help. If you need further assistance please let me know.
If you do not mind, would you please rate my help. I would very much appreciate it. Thanks
Posted on Dec 08, 2008
What is the different zener diode and ordinary diode
Posted on Mar 11, 2011
    Scholar:
  • 134 Answers
A conventional solid-state diode will not allow significant current if it is reverse-biased below its reverse breakdown voltage. When the reverse bias breakdown voltage is exceeded, a conventional diode is subject to high current due to avalanche breakdown. Unless this current is limited by external circuitry, the diode will be permanently damaged.
In case of large forward bias (current in the direction of the arrow), the diode exhibits a voltage drop due to its junction built-in voltage and internal resistance. The amount of the voltage drop depends on the semiconductor material and the doping concentrations.
Zener diodes are widely used to regulate the voltage across a circuit. When connected in parallel with a variable voltage source so that it is reverse biased, a Zener diode conducts when the voltage reaches the diode's reverse breakdown voltage. From that point it keeps the voltage at that value.
i hope it helps!!!
    President:
  • 2,110 Answers
I thnk No...It will wrk in only reverse bias for voltage regulationn
Do I check WB27X1160 hi-voltage diode as I would a standard diode?
Using a digital meter does not have enough forward bias to test the high voltage diode, in most cases it will short or crack making it easy for the meter to check.
Jul 23, 2012 | GE Microwave Ovens
Tip
Shorted Rectifier Diode (fuse keeps blowing)
This CRT tv is dead set, no reaction when the power button is pressed(no standby led light). I've open the back panel and check the faulty parts.
As you can see the fuse was badly burnt-out indication of excessive current due to short circuit.
I've checked the parts feeding the AC line to the power supply board (Power cord, VDR, Ceramic capacitor, Coil, Posistor, Degaussing coil) one by one and I've found out that one of the four rectifier diode has a leak which caused the glass fuse burnt-out.
Here's how to test the rectifier diode.
Good Diode
Note : Forward and reverse bias depend on what type of ohmmeter are you using, here I'm using a Japan Standard(Sanwa Brand).
Using an ohmmeter set it to X10 to see much easier the leak from the diode in reverse bias.
Forward Bias : test the diode by connecting the red test prod of the tester to anode and then the black test prod to cathode of diode. You will see the pointer will reads a faily low resistance(above picture).
Reverse Bias : test the diode by connecting the red test prod of the tester to cathode and then the black test prod to anode of diode. You will see at the picture(above) that the pointer didn't react (remains in infinity). This is a good diode.
Bad(leaky) Diode
Forward Bias will reads fairly low resistance.
Reverse bias unlike the good diode the pointer will also reads a fairly low resistance.
After confirming that the diode caused the fuse from blowing I've decided to replaced all four diodes since I have a lots in my stocks.
Remember that when you installing the new diode on the board, make sure that you will make it in the right polarity.
This steps is also applicable in the DVD Player,Flat panel, Projection, LCD TV, you have to disregard only the posistor and degaussing coil.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
on Mar 02, 2011 | Televison & Video
1987 Shadow 700 charging problem
yes there is a couple of different ways to test these components,first you will need a voltmeter and the first test is an ohms (resistance) test unplug the stator and place the meter leads on the stator leads 1and 2 then 1and 3 then 3 and 2 should read between .2 and 2.5 ohms then do an insulation breakdown one lead to stator lead the other to ground should read OL or OFL if any reading stator is junk. Then test out put meter to ac-volts meter leads to stator leads start the bike should read 15-100 vac. Then as far as the reg/rec goes set meter to diode mode and place one meter lead to the power output and the other to the stator input side of the connector do this to all three wires and then rev. the meter leads and do again 0.3-0.8 forward bias OFL in rev. bias then place meter lead to ground wire on reg/rec and do the same test if you get readings in both forward and reverse bias the reg/rec is bad replace
Jun 04, 2010 | 1987 Honda VT 1100 C Shadow
Cb was hooked up backwords +-/-+ can it be fixed
Some of the car electronics will put crowbar DIODE in the unit, the Cathode will be connected to the incoming positive, and the ANODE will be hooked up to the Neagative, the DIODE will not conduct because ti will be reverse bias, so when the positve and negative is hooked up wrong to the unit, the Diode will conduct (forward bias) with a lot of current and blow the fuse that is inline with the unit, you should be able to connect the Ohm meter to the positive wire and the negative wire of the CB (remove it from the car first), if it indicate anything lees than 100 Ohms, the protection DIODE is shorted out and protected your CB, you just need to locate that Diode.
Nov 01, 2009 | Cobra 29 LTD CB Radio
Akai PDP4225M red std/by light on
Stevenson
There is a difference between diodes and capacitors. The role of a diode is to rectify and some cases regulate voltages. Meanwhile, a capacitor is there to hold charges. Back to your question, to check an schottky diode, you need an ohmeter with a diode symbol, the reading starts like this .500, .600, .300. 125. still consider good forward bias. .1200 or infinite reverse bias is consider good still. But it shows 0 continuity then that diode is bad. You can also use ohm's law, resistance to also check a diode. Please e-mail me if you some further lesson at Stevebuy31@hotmail.com
Dec 01, 2008 | Akai PDP4225M 42 in. Plasma Television
My machine will not read previous dvd's recorded on it
Hello john750,
You can try a cleaning disk, however it has been my experience that the cleaning disk will not help, but it is a good place to start from. More then likely it is a problem with the laser pickup photo-transistor, these often malfunction causing this problem. I would suggest if you are going to try to repair this yourself, you will need a multimeter, a laser meter, and a schematic. The first step is to measure the laser energy leaving the laser diode and see if it matches the specifications in the schematic, if it does not, check the bias voltage with the multimeter, this is to determine if the problem is the bias voltage or the diode itself. If the diode is bad replace it. if the diode is good then the pickup becomes suspect. Using the multimeter measure the bias voltage on the photo-transistor with and without the presence of the laser light from the diode. This will tell you if the photo-transistor is good or bad, if the transistor is bad replace it , if it is good check the components that make up the biasing circuitry.
Now This test will produce a test of go or no-go on the laser diode and the photo-transistor. One of these components or their related biasing circuitry is either bad or about to go bad, by testing the voltages and laser light levels you should be able to determine which one or if both have a problem.
I hope this helps,
Thank you,
Shuttle83
Oct 08, 2008 | Televison & Video
I have a etec dvd player what freezes when it playes
Hello tasman_s
I posted this awhile ago, but I think it may help you:
Remember, at least try the cleaning disk first.
I hope this helps,
Thank you,
Shuttle83
Ilo 32hd blown fuse
Diodes are often parallel to other components so if one measures 'bad' it should be desoldered on one end and checked again.
On the diode test position of most all digital meters, they will show between ~400- 900 depending on the type if the lead polarity biases them in the forward (conducting) direction. The indication isn't really too meaningful but roughly equates to millivolts of voltage drop in the forward (conducting) direction. Reversing the leads, especially on the diode range should just cause an over-range indication or the same as when the leads are not attached to anything. Shorting the leads should show very close to all zeroes.
Aug 30, 2008 | iLO V27DMBX Television
Mintek dvd portable freeze
Hello mark85,
I posted this some time ago but I think it can help you, so here it goes:
I hope this helps,
Thank you,
Shuttle83
Aug 09, 2008 | Mintek MDP-1810 Portable DVD Player
Wired backwards
Yes Yes Yes. Before anyone tells you different, Yes. The smoke is supposed to happen when you do that. That is a protection diode that fried. It is there for that reason only. In rare cases, more damage can be done, but about 98% of the time it just fries that diode.
You can take it to any cb shop and have it repaired, just tell them the protection diode was fried. They should only charge between $10 and $15 for it. I charge my customers $10.
If you do not have access to a cb shop and are handy with a soldering iron and desoldering iron, I can walk you through this repair. Just let me know. You can post here or email me at rollincbmods@yahoo.com
Dean
Rollin CBs
Jan 28, 2008 | Cobra 29 LTD CB Radio
HP Pavilion dv6000z Notebook Logo
405 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
