Failure to boot up/freezes on boot up
Notebook refuses to boot up it is my nieces notebook and she has lost all literature.....need to know which f key is needed to re-format..
hope you can help.
brian
  • handyg2 Jan 12, 2009
    If you flick F10 after power on you may get to the Bios screen but on mine I lose keyboard function from this point. Hard drive removed and connected by Hard drive / USB cable enabled existing data to be unloaded you should be able to do the same via any PC support agent. My web&tel research indicates this is a "known" mother board fault and can be fixed for £160 not decided if its worth it on a 3 year old PC
    President:
  • 2,110 Answers
It may be F10 or F12
Posted on Dec 08, 2008
I have a acer 5315 laptop my niece forgot her sdmin password now cant get into or do anything does anyone know how to find lost password ? thanks
Re-install Windows, CAREFULLY choosing to install into a different folder-name -- not the 'C:\WINDOWS' folder. Then, you'll have access to all the files from the "old" installation of Windows.
Aug 22, 2010 | Acer Aspire 5315 Notebook
Problem with a Dell Inspiron 1545
There is an spot under the computer that you can open to access the memory ram, once there just remove them and put them back in..try that
Feb 26, 2010 | Dell Inspiron 1525 Notebook
Computer freezes and shows a fault screen
Remove all the physical components of your computer and have it clean. You can use a brush or a blower and then reinstall your computer operating system. If it is windows xp then you will be needing the software for windows xp installation and then support cd for your motherboard and all support drivers.
Nov 15, 2009 | Acer Aspire L100 PC Desktop
My computer will not turn on. My niece turned off my power strip and now my pc will not boot back up.
try putting the computer plug in a different wall plug sounds like you have a worn out plug causeing your problem.
Oct 05, 2009 | E-Machines eMachines Desktop PC
Reboot or repair harddisk
Please be a little more specific as to when you are recieving the error and word for word exactly what it says. Its hard to determine if it is a hardware or a software failure at this point. You could try booting off a windows xp disc, going into the recovery console and using the command chkdsk /p /r, it will try and locate bad sectors on the harddrive and fix them. I should let you know that harddrives are usually the first hardware component to fail in computers and have a life expectancy of 3-5 years.
Jul 12, 2009 | Compaq Presario CQ60-212US Notebook
Want to wipe hard drive on dell dimension 8250
You don't need a recovery cd (or any other cd) to wipe the hard drive. Boot to a command prompt and type "format c:"
Reinstalling your operating system is the only time you need a recovery cd. If you have no way to reinstall your operating system, don't wipe the hard drive.
Jun 30, 2009 | Dell Dimension 8250 PC Desktop
After fdisk and format of hdd install of os freezes after 2min. when it says windos is starting, tried differant versions of windows does the same thing!!!! Please help!!!!!!
PXE media failure means the system is trying to boot via Network card not your hard drive. When you performed fdisk then formatted the disk, you might have not selected an active or logical partitioning to support the OS. Run the PSA diagnostics by holding the Fn button before turning on your computer. If it gives you an error, it means your HDD has gone bad and needs to be replaced. If it freezes during the the loading of files during the installation, it means that your RAMs are bad because the windows loader dumps all the information to the RAM chips. If it does hang during the installation of files, two points of failure are to be looked upon, the RAMs and the HDD. I recommend you reset the BIOS to the factory settings as to reset the boot priority so it does boot to HDD first, not to any of the bootable drives available on your computer.
May 15, 2009 | Dell Inspiron E1405 Notebook
Cant re-boot
since ur computer is infected with the virus all u need to do is that if it is wired internet connection all u need to do is u need to go to the safe mode with networking by pressing the power button and then keep tapping the f8 key on the keyboard and then select the safe mode with networking and then log into the wiindows and then try and connect to internet and ran the antimalware byte and run the smitfraud fix and also run the combo fix find it at www.gur.in or u can call up the cyberdefender.com (premium tech support ) for the advanced troubleshooting steps).
Jan 20, 2009 | Acer TravelMate 2300 Notebook
Kernel library refuse 2 load after booting touchpad,keyboard frez
can you do a windows update
for some reason the kernal library has been removed
and if that does'nt help can you do a system restore
Jan 18, 2009 | Computers & Internet
Possible hard drive failure on SLIMNOTE N12PI
I don't think its a hard drive failure thats causing that message, basically PXE means your computer is trying to boot from a network/server. All you have to do is go into your BIOS setup right after your computer boots. Then make sure your BIOS is set to boot from your hard drive and not anything else (floppy, network etc.). And if possible disable any PXE settings.
Dec 30, 2008 | Twinhead SlimNote N12PI Notebook PC
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
