Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Kitchenaid won't start
I have a 15 year old kitchenaid mixer. I use it a lot, and recently, it wasn't running at the highest setting anymore for whipping egg whites, etc. Just medium. The other day, I went to use it, and nothing. Not at all, won't even turn on. I have no idea if there is flour or sugar or something stuck inside, or what the problem could be . Any suggestions?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, you describe problem could refer to any of the components of the mixer. Diagnosis and eventual repair would be relatively easy if you have access to a continuity tester. To be tested are:
  • the AC plug & cord;
  • speed controller switch;
  • speed controller itself (if used);
  • the motor which include the brush & commutator segments.
Should you be uncomfortable doing a DIY (do-it-yourself) repair. then your options are:
  • seek the services of a qualified professional;
  • consult KitchenAid @ 1-800-334-6889;
  • avail of KitchenAid's Authorized Service Centers.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 08, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
    President:
  • 2,110 Answers
Yes ur motor seems to have some problem so needs to be replaced in service center...
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
My house was recently struck by lightning and my KA mixer was a victim. All ten speeds spins at the highest speed. Any suggestions?
You need to adjust the mixer speeds:
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted. Make sure that the Control
Plate is not damaged in any way, contacts are not charred or burnt,etc...
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 28, 2011 | KitchenAid 32685 Mixer
When I turn on my Kitchenaid mixer at any speed, it ramps up to high speed and then shuts down after maybe 30 seconds.
You need a reputable repairman. My gears were stripped after trying to mix a very thick dough. It would only work on high speed. After it was repaired.... I still use it, all the speeds work, and that has been 15 years ago. My mixer was at least 8 years old at the time of the "stripping".
Aug 21, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Ksm90 mixer won't unlock
Look for a reputable dealer that repairs KitchenAid mixers. It is worth the little extra money to keep it going well. I had a much needed repair 15 years ago...... it was 8 years old then, and it is still in great shape and working superbly!!
Aug 15, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid hand mixer (about 18 years old) works great, but the beaters keep falling out
ROTHL, you must be joking. 18 years?!? You're lucky it still turns on. In the last 18 years (I do a lot of cooking), I've gone through 5 hand mixers.
Buy a new one.
Oct 19, 2009 | KitchenAid Food Mixers
Mechanical burning smell on kitchen aid stand mixer
i think its time to retire it its has had a good run time to put it to rest and buy a new on it don't sound safe to use anymore
Sep 21, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Motor is running but the paddle won't move.
If you bought this mixer less then 1 year ago, call KitchenAid at 800-541-6390. They have a "hassle-free replacement" warranty. They should ship you another mixer. I bought one recently and it died after 3 days of use. I called and they are sending me a new one. However, it is not comforting that these mixers fail so quickly. KithenAid use to be made a product to last many years. I assume the quality has declined. Good luck!
Dec 22, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
41 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
