Question about Pioneer DV-525
Pioneer DV-525 Parental Lock?
On the setup menu how do activate the parental lock? If of course, there is one. (Just cought my 3 year old trying to put on Predator!!) Thanks Adam
  • 845 Answers
SOURCE: How can I make my Pioneer DV-525 Region Free?
Unfortunately you can't make it 'region free' but you can change the region as follows:
* power up the player without a disc init.
* press setup on the remote control,an osd will appear on the tv.
* select GENERAL using right cursor and use down cursor to select BASIC,press ENTER.
*press DISPLAY, the current region will be displayed.
*press CONDITION/MEMORY followed by 1,2,3,4,5,6 dependent upon the required region.
* press SETUP.
* your player is now ready for use
Posted on Feb 19, 2011
0 characters
1 Points
NEC NDT-40 DVD/VCR has "child lock" engaged
Try this:
If you forget your password If you forget your password, you can clear it using the following steps: 1. Press SETUP to display the Setup menu. 2. Input the 6-digit number "210499" and press ENTER/OK. The password is cleared.
1. Press DVD on the remote control.
2. Press SETUP. The Setup menu appears. 3. Use v / V to select the desired option then press B to move to the second level.
LOCK (Parental Control)
Rating Blocks playback of rated DVDs based on their content. Not all discs are rated. 1. Select "Rating" on the LOCK menu then press B. 2. To access the LOCK options, you must input the password you have created. If you have not yet entered password, you are prompted to do so. Input a password and press ENTER/OK. Enter it again and press ENTER/OK to verify. If you make a mistake before pressing ENTER/OK, press CLEAR. 3. Select a rating from 1 to 8 using the v / V buttons. Rating 1-8: Rating one (1) has the most restrictions and rating eight (8) is the least restrictive. Unlock: If you select unlock, parental control is not active and the disc plays in full. 4. Press ENTER/OK to confirm your rating selection, then press SETUP to exit the menu
Unlock New DG AU Move Select
Sep 18, 2016 | NEC DVD & Blu-Ray Players
Parental controls
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Jul 07, 2013 | DVD & Blu-Ray Players
How do I shut off or disable TV Guardian?
Setting TVGuardian®
To set "TV Mode Strict", "TVG CC On" and "TVG CC Ch
1* Press [SETUP] in the stop mode.
The setup screen appears.
2* Press [ => ] to select "Parental".
3* Press [ENTER].
"Parental" screen appears.
4* Press [Down Arrow button] to select "TVG Mode".
If the parental lock is set, the highlighted box does not
move. You must enter the password to release the
parental lock first.
5* Press [ENTER].
The submenu ("Off", "Moderate" and "Strict") appears.
6* Press [p] to select TVG mode to OFF at this window, if it is selected strict.
Jul 13, 2011 | Sanyo DWM395 DVD Player
I inserted a DVD and the words parental control limit comes up on the screen. It's rated R but I have received many dvds from Netflix rated R which played with no problem. There is a bar with a picture...
If you are able to, go into the setup menu, select 'parental control', check the rating (8 is restricted - 1 is no restriction), and 'unlock' (if you have not set a password) then exit the setup. This should solve the issue for all future discs (parental lock is a pointless feature in DVD players, as often, owners set passwords, only to forget them later, so they cannot undo this function).
* This is for a Zenith XVB442 DVD/VCR combo, but essentially a similar setup *
If you forget your 4-digit password
If you forget your password, to clear the current password
follow the procedure below.
1 Press SETUP to display the setup menu.
2 Enter the 6-digit number 210499 and then press
The 4-digit password is cleared.
3 Enter a new password then OK.
I do not recommend setting parental lock passwords in DVD players, but you may not need to do this, so the above is a 'just in case'.
Apr 19, 2011 | Zenith DVD & Blu-Ray Players
The parental lock is on and I can't get rid of it. When you turn the unit on, it goes to 'lock' and won't let you go any farther.
Try taking any dvd or tape out of the unit, then using the remote, hit the menu button on the remote. From there, go to the set up or preferences menu. (If you havent set a parental lock code, you may need to do that first.) You can set your preference for what rating and how often the parental lock is in effect.
I hope this helps!
Mar 02, 2011 | Apex Digital ADV3800 DVD Player/VCR
Parental password control inadvertently activated.
Called Zenith. They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!
Nov 11, 2008 | RCA DVD & Blu-Ray Players
Sansui dvd san4312
DVD players don't need parental locks. When a user places a DVD player in Parental Lock mode, they usually create a 4-digit access code to remove the lock. Without the manual, I can't tell you how to reset to factory settings...what you need is either the access code or to reset it.
If it came direct from the factory with a parental lock already on, try the code "0000". If you need more digits, just use 0 until all of the slots are filled. If 0 does not work, try all 1s or 9s.
May 03, 2008 | DVD & Blu-Ray Players
Parental code
although my situation was a bit different, part of msimeomix's solution still worked. after entering the password "3308," the screen went blank. i knew this parental code had worked but it would still not allow me to access the "setup" or "menu" options. i pressed "STOP" and then ejected the disc/turned the DVD player off. upon turning it back on and entering the password "3308" i was able to immediately press "PLAY" and it worked. enjoy the movie :]
Mar 23, 2008 | Daewoo DV-6T955B DVD Player/VCR
Zenith dvb410 parental control
Without the DVD in the player go into your setup menu. Arrow down to the icon that is a lock press enter. arrow down to password and if it says new or change select it. you need to enter a pass code so that when the prompt comes up you can override the parental limits.
if you need to clear your old security code because you have forgotten it the manual says to input the 6 digit number from teh setup menu "210499" I did not do this as I had never set up a security code but the Across the universe DVD will play as long as enter the security code.
Feb 15, 2008 | DVD & Blu-Ray Players
How do you reset the parental control code?
Aug 24, 2007 | Zenith DVB412 DVD Player
Pioneer DV-525 Logo
43 people viewed this question
Top Pioneer DVD & Blu-Ray Players Experts
Steve Sweetleaf
Steve Sweetleaf
Lawrence Oravetz
Are you a Pioneer DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
