Question about Genius G-Pen F610 (31100050100)
G-Pen F610 versus Photoshop 7
I recently bought the tablet G-Pen F610 Ultra Slim and I was trying it out in Photoshop 7. The pen works fine, but when I choose one of the
brushes, like a 45 pixel brush and then I use it , it still gives me a brush of 9 pixels. But it is very hard to work with it because now I don't know the size of the brush, if I pick one out. I don't have it with my mouse.
Is there any solution to it, to avoid it are work around it. Now I have to
guess where my line would begin.
I believe I understand what you are referring to. I can reproduce this same effect in Photoshop 6. The settings for tweaking this and other options like opacity is under the "BRUSH DYNAMICS" button for the particular brush. The default seems to have SIZE set to be managed by the STYLUS pressure. If this is changed to OFF, the size will remain constant, and you can use stylus pressure to change another dynamic. Hope this is of some help.
Posted on Dec 19, 2008
Tablet cursor works for a few seconds then freezes (G-Pen F350; Windows Vista). I've uninstalled and reinstalled the driver 3 times already. The tablet worked perfectly fine yesterday when I bought it, but...
Hi
Is that the same with computer. If yes, just run the system restore. choose the date you want to restore.
If not, uninstall software that you install before that might corrupted the program.
Mar 08, 2011 | Genius G-PEN F350 Ultra slim tablet....
Replacement Pen for G-Pen F610 isn't working very well.
nomally happens the 1st time you use.
log off and back on again.
otherwise reset ... it should work next time you boot up.
Jul 21, 2010 | Genius G-Pen F610 (31100050100)
Photoshop cs4 pen pressure not working. Windows xp. Have the latest photoshop update and Wacom tablet update. running Cintiq. Have tried reinstalling tablet and photoshop...did not fix issue. ...
In photoshop, press F5 to bring up your brush control window. Under shape dynamics and other dynamics and any other brush attributes you wish to control with your pen, make sure that control is set to "pen pressure" in the drop down menu. Hope that fixes it for ya.
Dec 16, 2009 | Genius G-PEN F350 Ultra slim tablet....
Software and or Photoshop problems - no pressure sensitivity
In photoshop, press F5 to bring up your brush control window. Under shape dynamics and other dynamics and any other brush attributes you wish to control with your pen, make sure that control is set to "pen pressure" in the drop down menu2_bing.gif. Hope that fixes it for ya
Aug 17, 2009 | Genius G-PEN F350 Ultra slim tablet....
Photoshop not recognizing pen pressure in CS4
check that all connections from the drawing tablet into the pc are secure
Jul 16, 2009 | Genius G-PEN F350 Ultra slim tablet....
Pressure senstivity doesn't work in CS4
Jun 26, 2009 | Genius G-PEN F350 Ultra slim tablet....
No one knows how to turn on pen pressure for photoshop 7
If you haven't tried this yet:
First go to "Windows" on the task-bar of Photoshop.
Go down and select Brushes.
A window should pop up with several different setting for your brush. Check the Shape Dynamics if it isn't checked.
And then the pen pressure should work I believe. Hope I helped.
Apr 11, 2009 | Genius G-Pen F610 (31100050100)
Problem with g-pen 610
hi there... Good news.. problem solved.. i was facing the same problem like thousands of others. not able to install the tablet f610 on to my macbook pro.
the solution turned out to be simple....
i went to the genius site.. go to products... tablets.. and under there somwhere u will find dowloads link... just download the  driver that you need.. ..
it will work.
best of luck
peter dsouza
Feb 21, 2009 | Genius G-Pen F610 (31100050100)
G-Pen F610 blind spot (pen won't move over particular section)
Sometimes it is caused by a metal plate coming in contact with the sensor pad inside of the tablet. It is only fixable by dismanteling the tablet and putting an A4 sheet of paper between the back side (the one that has the metal plate which can be the culprit) and the green pad (do not touch it!). This issue usually appears after continuous use when the green sensitivity pad is pushed down a little and is short-circuited by the metal pad on the inner side.
Dec 28, 2008 | Genius G-Pen F610 (31100050100)
Pen Sensitivity not working
go to
http://driverscollection.com/?file_cid=40927217892cec14ec94967bbb1
Dec 20, 2008 | Genius G-PEN F350 Ultra slim tablet....
Open Questions:
See all Genius G-Pen F610 (31100050100) Questions
Genius G-Pen F610 (31100050100) Logo
908 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
