Question about Kitchen Ranges
Chef fan forced oven stopped heating up - fan and lights still working OK. Screws on element are stuck
  • 171 Answers
The first thing that goes bad is the element, electric stoves work like the light switch on the wall and light bolt. the element is like the light bolt and the thermostat works like the light switch on the wall. and like the light bolt they do go bad often. so the element needs replacing. but before that i check for power to the element, making sure the thermostat supplies electricity.
Posted on Dec 10, 2008
Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Dec 13, 2016 | Ovens
Chef Norfolk Deluxe fan forced oven. Oven, lights and separate grill - all lights went out, lost heat and stopped working.
there is a fuse inside the plug,unplug it to check it,please report the other posts
Jun 15, 2015 | Ovens
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Fan and element not working
hi not sure if you've had a reply but when my zanussi main oven stopped working i just changed the element (purchased from e bay).
open oven door and the back you will see 4 screws(basically 4 corners) remove these screws and you will see the element, pretty straight forward to remove, obviously fan wont work until you have heat (hopefully fan ok) you can give this a go, cheaper than buying a new oven. i have done this twice. hope this helps.
Mar 10, 2014 | Zanussi ZHQ575 Electric Double Oven
My Chef Select fan forced oven has no heat. I have replaced the fan motor and the element, but still no heat. What else could be wrong with it?
Check that it is not been set on automatic. Try turning the timer /clock control through 24hrs and it may go click, fixed
Feb 21, 2013 | Ovens
Fan forced heat stop working and I open the panel cover inside to check the element size etc to replace. But element is fixed to the wall with three screws, one in the bottom of the loop and two on top on...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 17, 2011 | Smeg S351X/5 Electric Single Oven
Hi. My oven stopped getting hot (elements still get barely warm) right after the temperature sensor broke off. Could the broken sensor cause this? Thanks.
yes it can and ur element is probably bad shut off power take out 2 screws on side of it n pull ito ut to disconnect wires n put new one in !!
Apr 07, 2011 | Ovens
My cooker won't heat up
remove the rear panel covering the fan (4 screws) from inside oven. The element is round the fan. you may see where the element has burnt through or split or distorted the element.
Jul 23, 2010 | Electrolux Ovens
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Kitchen Ranges Logo
693 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
