Question about Car Audio & Video
Hyundai sona98A radio and audio do not work - Car Audio & Video
Radio has static on the AM station, also radio does not have good sound coming from speakers. I have tried to tune the radio but it still sounds very monotune The music coming from Radio sound bad.
Posted on Apr 22, 2009
Reset audio head on 2013 Hyundai Elantra
remove battery neg cable for 15 minutes then retry radio buttons. it will some times help with that otherwise it is internal radio issue
Sep 29, 2017 | Hyundai Elantra Cars & Trucks
Hyundai audio system in acting weird?
What happened, you forgot to pay your radio bill? Now for the solution. I suspect you tend to turn on the headlights to see in the darkness. That may be the hint that will help find the problem! Try turning on your headlights at the times you say it works and see what happens. If the radio goes off, you have a short somewhere that shorts out the radio power!
Jan 11, 2013 | 2009 Hyundai Tucson
Hello. Have just bought a 2006 tucson,battery was disconnected but have tried to recode the radio using the code on the blue card provided but no go. It times out after 3 times for an hour. Is there any...
Hello Colin. You describe a radio which doesn't sound like any Hyundai Radio I've ever worked on. It seems to me the audio unit is 'after-market' and isn't supported by Hyundai Motor America or Hyundai Service Departments. Does it have a "Hyundai Emblem" on it? If it does, you can check with any Hyundai Service/Parts Department & have them check the serial no.
Aug 28, 2011 | 2006 Hyundai Tucson
Need radio code for 1993 hyundai gl changed batteries and don't know the code. Radio serial number hf21000474 -- --- --
need to notify dealer call first they will advise how to retrieve radio id code which will aslo be needed with id proof of ownership and code dealer will be able to give u code
May 09, 2010 | Car Audio & Video
XM Radio in 2008 Hyundai Sonata sounds bad
Same problem here. I repeatedly complained to XM but got no reply. I listen to XM in 2009 Sonata and it was just as bad.
XM is better than AM. Much worse than FM.
Oct 14, 2009 | 2008 Hyundai Sonata
How to remove 2001 hyndai sonata audio system
Instructions
Things You'll Need:
  • Screwdrivers
  • Wiring harness adaptor
  • Hyundai radio adaptor kit
  1. Open the coin holder and remove the two screws at the front. Pry the trim from around the gearshift lever and unhook the power wire to the cigarette lighter.
  2. Locate and remove the two screws from the bottom of the radio trim panel. Look for the screws, attached to a rod, below the glove box. Unhook the cable from the rod and pull the rod free.
  3. Place the shifter into "D" and slide the radio trim panel away from the dash. Locate the four screws at the front and sides of the stereo and remove them.
  4. Pull the stereo out of the Hyundai Sonata dash and disconnect the wires from the back of the unit. Connect the wiring harness adaptor to the original harness.
  5. Slide the new head unit into the Hyundai radio adaptor kit. Attach the wiring harness adaptor and antenna wire to the back of the new head unit and push the entire assembly into the dash.
  6. Secure the stereo in place with the four front and side screws and turn it on. Verify all of the speakers and features are working. Reattach the radio trim panel, insert the rod back into cable assembly and secure the trim around the gear shift.
In here you can find tips about remove radio...
- Hyundai Car Stereo removal
- Stereo Removal Hyundai (buy)
I really hope help you with this (remember rated this help). Good luck.
Oct 01, 2009 | 2001 Hyundai Sonata
Stock radio won't tune into an FM radio station.
check you attenna connection otherwise it has lost it's ability to seek and stop
Aug 11, 2009 | Hyundai Electronics Hyundai Elantra 2004...
The radio switches to cd player and er2 message
Audio head 'INTERNAL' malfunction. Non repairable by Hyundai Service Center - solution is replace the radio.
Jun 05, 2009 | 2002 Hyundai Santa Fe
No unlock code for Philips car audio
You need the vin number of the car the radio came from and also you need the serial number of the radio. Together with this info, go to a Hyundai dealer and for a small fee they will get the unlocking code from the data base.
Jul 31, 2008 | Pioneer 10-Inch Subwoofer Grille Udg256
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
