Question about Zanussi FJS1225W Front Load Washer
Washing machine wont spin
New samsung wa13r3 wont spin even though it is on a flat surface whats wrong?
  • Zanussi Master
  • 3,463 Answers
If when you say it is new, then if it is under a year old, then you should contact your service agent, or the retailer. There are many reasons that would stop it spinning.
Posted on Dec 08, 2008
I there, i have a samsung top load washing machine model wa13r3 it washing and draining and rinse but when it spin it psin slowly when done the washing is still wet.
it could be the motor as they have 3 phase wiring if other 2 are working but this one is not most problems is down to the motor. you would need to check the motor with a meter to find out as if not the motor it could be the electronic switch that feeds power tot that setting. to fash spin.
Jun 29, 2017 | Samsung Washing Machines
Can't spin. Makes ratcheting noise as it attempts to start spin, can't start spin even w/o load.
What to do when Samsung Washing Machine does not spin ?
www.samsung.com/ae/support/skp/faq/1033383
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
How to Fix Washer That Won't Spin ' Washing Machine Repair
Nov 28, 2015 | Washing Machines
Loud noise from tub when on fast spin aquarius wma48 1400 spin
possible causes are
Overloaded Machine
Putting too many items in your washing machine at one time or washing larger items, such as a quilt, can cause your washing machine to occasionally make excessive noise. Laundry can get trapped around the agitator and will hamper its movement, causing it to work harder to spin. Stop the wash cycle and remove the excess laundry on top. Take big, bulky items to a laundromat or drycleaners to wash in an industrial machine equipped to handle such items. A washing machine is more effective at cleaning laundry when water and suds can surround the clothes and penetrate fabrics.
Defective Balancing System
GE washing machines have a balancing system that includes counterweights, springs and pistons that help to evenly distribute weight inside the wash tub. If any of the system's components break, it can interfere with the drum's rotation. Rather than spin evenly in the machine, the drum might be imbalanced up or down and produce a knocking sound. The noise might become louder and more persistent each time you do a wash load until you replace the faulty component.
Washing Machine Not on Level Surface
Place your washing machine on a flat surface, preferably a concrete slab. If the floor underneath the washing machine is sloped, even the slightest bit, it can cause the machine to vibrate when it spins and agitates. Place both hands on either side of the washing machine and try to move it. If the machine moves, then adjust its feet at each of the bottom four corners of the machine by tightening or loosening the bolts with a wrench until the machine is level on all four sides.
Jun 10, 2011 | Hotpoint Washing Machines
The laundry is still wet after a normal wash cycle, because the machine doesn't get into the "high speed spin" (this has happened several times . . . have only had it 2 weeks). It has happened on full...
Since it can spin by selector then there is no problem with the spinning mechanism. Need to call warranty service to address the electronic sensor control.
Jan 09, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
Bendix 800 autowasher de luxe, drum spin snagged then cleared.
should b nothing off this description on ure machine unless the pump coil has over heated iff so just replace coil and check for blockages
Jul 13, 2009 | Tricity Bendix AW1000W Front Load Washer
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Samsung WF337AAL/XAA washer- washing mashine with noise reduction but when it spins we hear a lot of noise and the unit moves. What can we do?
I have had mine for 6 months. I noticed that they must be on a flat smooth surface. If the surface is not level you will have that problem.
Jul 13, 2008 | Washing Machines
ZWF1432W Zanussi Washing Machine
has the transit brackets been removed, these are bolts that secure the drum while its being moved, failing that this could be a call out under guarantee, the bolts and location of where they are etc are in the instruction leaflet and differ from machine to machine etc
Oct 03, 2007 | Washing Machines
Zanussi FJS1225W Front Load Washer Logo
193 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
