Hi, I purchased an Acer L100 desktop. My problem is I unable to take control of the pC. I need to reset the administrator profile as another family member has corrupted the users files and I am unable to take control of the administrator user to load or delete programs. I hope you can help. Jim
  • lexusjim Dec 08, 2008
    Hi ,
    It came installed with Windows Home Vista and not XP.
    Regards
    Lexusjim
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try this:
  • Click the Start orb and click on Run (or press the Windows key + R);
  • Type in regedit and press OK. If it asks you to open this via UAP, then click Allow.
  • In the Registry Editor, navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon.
  • In the right hand pane, right click the mouse and select New then Key. A new folder should appear in the left hand pane.
  • Name this new key SpecialAccounts and press Enter.
  • Right click the mouse on the new SpecialAccounts key in the left hand
  • pane, select New then Key again to make a "sub-key".
  • Name this new key UserList and then press Enter. In this new UserList key, right click in the right hand pane and select New then DWORD (32-bit) and name this Administrator then press Enter.
  • Double click on the new DWORD you just made, and set the value to 1 thenpress OK.
  • Restart the computer to see the effects - from the Welcome screen youshould be able to login as the administrator any time you wish.
Before you restart make sure you check this setting, click Start, Run, type in compmgmt.msc, hit OK. Under "Local Users and Groups", select Users, double click on the Administrator then make sure "account is disabled" is unchecked.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 08, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
    President:
  • 2,110 Answers
Do u have recovery Disc,,If yes try to restore the system to factory setting...
  • 13,433 Answers
Hi
I would suggest you get your hands on a windows xp setup cd, assuming the pc is runing xp, do a fresh install of xp to get rid of the problem.
  • Ekse Dec 08, 2008
    The same advice for that, get a vista install dvd note that you need a product key, it should be on the side of the computer.
Why am i unable to access my control panel
If your on a works computer the network Administrator has locked down the control panel to prevent users gaining access, if your on a home computer you need to login as an administrator as the profile your using has restricted access.
Sep 24, 2014 | Computers & Internet
I have a Acer Aspire L100 and would like to restore to factory settings please help
If you have lost the automatic restore then you need recovery CD to restore it. To download try this link:
http://www.user-guides.co.uk/cddownload/Acer/AcerAspire/Acer-Aspire-L100-XP-Driver-CD-Recovery-Restore-Disk-115940.html
Apr 11, 2010 | Acer Aspire L100 PC Desktop
You asked me to clarify my issue with an Acer Aspire L100. My problem is, there is no video output from the system. It appears as if the onboard video has gone out. The unfortunate thing with this mini...
You do have 1 PCI slot in that system. So, you could purchase a video card and place in that slot. Since your video is on-board you'll need to disable in Control Panel - Device Manager. Good luck.
Jun 19, 2009 | Acer Aspire L100 PC Desktop
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
Go back to Acer.com. The driver you want is the one that say's (Power 1000 chipset driver) that is if it's an integrated Network card. If it's not integrated then I would need the name on the card. Hope this helps.
Nov 17, 2008 | Acer Aspire L100 PC Desktop
I am unable to use cd/dvd drives & usb
log in as administrator und use the user management control in control panel to enable your account to a power user
Oct 01, 2008 | Acer Aspire™ T180 PC Desktop
Acer L100 Graphics
The L100 has an onboard graphics card and is not upgradable.
May 09, 2008 | Acer Aspire L100 PC Desktop
Need password help for Aspire L100 with Windows Vista
Hello Freddy!
this is only a try. Switch on your system and then if your system prompted to supply password in any username thereto. just leave that instead. simultaneously press " Ctrl + Alt+ Delete" two times. Your prompted to supply " Username" and "Password":
On Username: type " administrator" all lower case
On Password: leave it blank.
and then click OK. may this solve.
If this not work then sorry i have to go on research about that.
Dec 20, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire Mini PC
Hi, you will be able to purchase a mini ATX format board by almost any manufacturer that will fit the acer case, the only problem you may hve is the PCI and Graphics cards will need to be low profile standards but these are also available if you are not planning on gaming then the on board graphics on most new boards will do all you ask of them.
Regards mistyman
Oct 14, 2007 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
