Question about InFocus SOFTCASE, LP425Z Multimedia Projector
Problem with INfocus LP425z Colorwheel ?????
I have had this projector for 6 years and have used it less than 50 hours. When you turn on the projector the fan turns on and about 5-10 secs later you hear a whining noise and then the lamp turns on. Two years after purchasing it, it would take a few times of turning it on and off before the whining would start and the lamp would light up. Now (RIGHT BEFORE SUPERBOWL) theres no whining or light. I was told by tech support that the whining is the colour wheel. The lamp should still be good with less than 50 hours used. Is it easy to open and look at the Colour Wheel?
  • 2,237 Answers
Even if it is the colorwheel, you wouldn't be able to get a replacement. infocus no longer has parts for the lp4xx series.
Posted on Aug 03, 2009
    Champion:
  • 205 Answers
That unit has a bearing color wheel, if it was not stored proper, it could be sticking. That would explain the power cycling. giving it a bump start if you will. Yes you can open and inspect to see if color wheel "free wheels"
Posted on Jul 09, 2009
Infocus lp425z projector pushes latop display to left quarter of output image
Usually this is a hardware acceleration setting problem on the 'advanced' properties setting in your 'screen resolution' properties on your computer. Re-set the hardware acceleration to the 2nd setting and this should fix your issue. We have this regularly when we project on a double projector system and the one projector keeps shifting everything left until we adjust the hardware acceleration settings on the computer. No more issue.
Mar 11, 2013 | InFocus SOFTCASE, LP425Z Multimedia...
Replaced bulb. Worked for a while then wouldnt power up again.
the cheew cheew cheew is the colorwheel not spinning properly. either the colorwheel motor is shot, the sensor can't sense it, or the power to it is too low. first thing: remove the cover and blow the dust out of it with canned air. dust does a lot of damage to these. if it is the sensor, cleaning it off might help. if it is the colorwheel, i have bad news: on the x1, the colorwheel is not sold seperately from the optical engine. you'd have to get the entire optical engine. now the worse news: infocus no longer makes or sells parts for the x1. you could try and find one on ebay that has a different problem and swap out the parts
Dec 29, 2009 | InFocus X1 Multimedia Projector
With all menu settings appearing with their normal values, my X2 projected image ''oscillates'' between showing correct colours and a heavy green overcast with no blues or whites. The green light is steady...
your colorwheel is going bad. needs replacment. find an infocus service center and purchase part # 525-0144-00. shouldn't be more than $50, but replacement is pretty involed. you need to remove the top case, front and back covers, power boards, plate, lamp house assembly, and fans just to get to where the colorwheel is plugged in to the main board. removal of the actual colorwheel is only 3 screws.
Jul 30, 2009 | InFocus Office Equipment & Supplies
REMOTE
good luck. infocus has nothing having to do with any of the lp4xx series. they don't even have lamps. try ebay.
Apr 11, 2009 | InFocus LP425z and LP435z Replacement...
?blown bulb
do you hear a high pitched whir or chirping? the whir is normal. the chirping is the colorwheel not syncing with the dmd chip. this will cause that image distortion. if the colorwheel is fine, then it's the dmd chip of the chip pcb that needs reseating or replacing.
Feb 20, 2009 | InFocus X1 Multimedia Projector
Flickering color, color flickers in and out
Check connections, board, and unit itself around the Color Wheel.
Feb 07, 2008 | InFocus SOFTCASE, LP425Z Multimedia...
Problem
Is there any lights that come on? or is it completely dead?
Cheers
Dec 29, 2007 | InFocus X1 Multimedia Projector
Color Wheel
you'll have to replace it. bad news: infocus doesn't make them anymore. sorry
Dec 07, 2007 | InFocus SOFTCASE, LP425Z Multimedia...
275 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
