Question about E-Machines T2682 (000002965) PC Desktop
Aded a gig of ram hd will not turn on and shift into a windows bo
Added a gig of ram to emachine with 256 meg when gis was added machine beeps three times when powered on and will not boot
  • 449 Answers
Check if your ram is okay
Posted on Dec 08, 2008
Hi
Well about guaranteed your 2 gigs ram is probably DDR II ram which has maximum of four gigs with 64 bit processing and 2 with 32 bit is. So motherboard needs upgrade. 35.00 for good giabit or board with 1000 megs a sec ethernet lan. With ddrIII ram. And upgrade operating system I believe win 8 has max 16 gig ram win 7 uses 8 gis vista and longhorn 64 use 4 and xp normal edition 32 bit uses 2 max. So you about have to run win 7 or 8. Win 7 will become direct x incomparable at some point making us change to win 8. Win8 cost like 300 to 350 and tiger direct.com has good deal of the win 7 pro media center for 75 bucks. So spend 150 on good speed 8 gig ram, 125 bucks for 12 core and at 4 GHz I think. And a board for 35. Reuse all other componets. And you\'ll have a 2500 dollar computer and best on the block. TigerDirect com Electronics Tablets Phones Office Supplies Video Games
May 16, 2014 | Video Game Consoles & Games
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I currently have just 256mps of memory ram on my dell dimension 2400. i want to upgrade. my manual says the maxium is 1024 mbs. can i install 1gb of ram or should i get 512 mbs? i have windows xp os. thank...
1024 is 1 gig of ram. Some older motherboards require you to put in ram in pairs but I don't think your system is one of those but if you have manual or can download manual you should check to be sure. If you don't need a pair then yes you can remove the 256 meg stick and add a 1 gig stick or you can put in 2 512 meg sticks. Should run a lot better as windows recommends at least 512 megs of ram.
Nov 20, 2009 | Computers & Internet
Why do my toshiba satellite only show 191 of ram when i have a 256 ram installed
There is nothing wrong. Your RAM may be special RAM that the computer uses some of the memory for something else.
Sep 23, 2009 | Toshiba 15.4-inch 1.6GHz 60GB Laptop PC...
Need to add hard drive and memory to emachine tower 333
Okay, this is what you do, I don't really think that Win 98 supports dual HDDs, but I think I can help.
If you have a IDE Dual Cable (plug into the Motherboard and have two connectors attached), Do you see the mini plug by the connector on the HDDs? (Usually white or different color) on the Original HDD, put the miniplug to "Master" and the second (added) HDD to "Slave" or you may be able to use the "Select" on both.
What I do recommend though is going ahead and burning all of your precious data to CDs and buying a newer HDD.
Instead of 4 Gigs, get something around 80 Gigs.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2948583&CatId=134
If you give me the motherboard specifications, you may be able to update your RAM to 128-256 MB
Mar 09, 2009 | Microsoft Windows 98 Second Edition for PC
Motherboard 3 beeps
The three beeps is a diagnostic code. The beeps can represent a range of problems depending on which brand of mother board you have and what chipset it has. You can sometimes find the diagnostics related to the beeps online. The first thing to check is to make sure all your cards and ram are properly seated into their respective slots. I suspect your ram. Speaking of which 256 meg sdram is not enough to run todays applications. You should step up your ram to at least 1 gig and if you are running Vista, you'll need 2 gig.
Feb 21, 2009 | Computers & Internet
I have an CF48 and a CF25 Personal Computer. I would like to know what size RAM and HD and Processing speed these laptops are issue with from the factory.
I looked up info i dont know if this the right computer you ment but
Panasonic Toughbook CF-48 CF-48X4HLUDM
Processor: Pentium 4 1.8 ghz Display Size: 14 inch Hard Drive: 20 Gig Memory: 256 meg Optical Drive: CDRW Drive (Burner) Floppy Drive: Built in PCMCIA Slots: 2 PCMCIA Slots Sound and Speakers: Built in speakers and sound Pointing Device: Track Pad Ports: 2 USB, 1 Parallel, 1 Serial, 1 VGA Modem: Built in 56k Ethernet Network Card: Built in 10/100 Operating System: Windows XP Professional AC Adapter: yes Battery: (not warranted) yes Warranty: Lifetime Limited Warranty
Dec 16, 2008 | Panasonic Computers & Internet
Cannot play games
One gig of ram is still very low for major gaming. For good gaming, you should have no less than two and preferred, you should have four or more. The card is ok as long as it is 256 megs of dedicated not shared memory.
Nov 12, 2008 | Asrock 775VM800 Motherboard
E-Machines T2682 (000002965) PC Desktop Logo
167 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
