Set up our router but we can't access the interneton any of our laptops
  • 3 more comments
  • Velaphi Masoha Dec 08, 2008
    i am connected to the vsat modem which gives out ip addresses dynamically, and a 881 cisco router.i cannot access the internet
    i can ping the router but not the modem.
    There 5 ports on 0-3 FE LAN and FE4 WAN.
    The router is not trying to give an IP Address,but it is getting its ip address on the FE4 from the vsat modem. its something to do with encapsulation.I am using CP.Its a new service
  • Loteck May 11, 2010
    So are these wired or wireless?
  • Boli May 11, 2010
    Is the cisco router trying to give an IP also?
    (is there an uplink port on that router? [cant get enough info])
    can you Ping the router and the vsat modem?
    Let me know...
    Matt
  • Eric Mitchell
    Eric Mitchell May 11, 2010
    Did you already have the internet or is it a new service
  • 733 Answers
Check the manual there is all the info you need to configure.
Posted on Nov 24, 2009
I need a password to reach the interneton my ipad...it asks for a cisco password
If your wireless router was setup using the default configuration, the password, also called a security key should be on the bottom of the router. Alternatively you should be able to specify on your ipad that you want to connect using WPS, and your router will have a WPS button on it. Pushing it for 2-3 seconds would allow your ipad to connect without needing the password. You should be able to google "connecting ipad to wifi using WPS" and if necessary include your router model to get specifics about the location of the WPS button on your router.
Jan 16, 2014 | Computers & Internet
Need driver and firmware for LinkSys RTP 300, or how to set it up for simple home network with interneton the PC and laptop as the 2nd computer.
No drivers are required since there is no actual installation to to the computer. Connect the ISP modem to to the main LAN network port. Then use any available port to access network. 1.Power 2.Main drop. 3.Network. That's it!
If the router is used, you may want to reset custom settings by, holding in the reset pin till it cycles.
Advance setup.
http://www.cisco.com/en/US/docs/routers/csbr/rtp300/installation/guide/RTP300_UG.pdf
Oct 16, 2012 | Linksys Rtp 300 Broadband Ethernet Voip...
Please I cannot connected to internet
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
May 26, 2011 | Computers & Internet
I can not get Interneton my dsi how can i can get internet
connect the dsi to your wireless router and then you will be able to use the internet on it
Mar 23, 2011 | Nintendo DSi White Console
How do u get on the interneton the dsi
You have to setup your internet connection on your DSI before being able to go on the internet and play online. Here is a step by step instructions how to setup your DSI Internet Connection: Wireless Connection:
  1. Turn on Dsi and click on the wrench button to go to system settings.
  2. Scroll until you see "Internet" and select it.
  3. Select "Connection Settings"
  4. Select "none" next to the Connection 1 button
  5. Select "Search for Access point"
  6. Select your preferred access point
  7. Test Connection
  8. Done!
Feb 23, 2011 | Nintendo DSi White Console
How do I access my router settings using the http://192.168.1.1? I set it up on another computer and always accessed it from there, Now I cannot access it from my laptop
hey,
you need to connect your laptop to the wireless router over wireless or wired connection and then access the page.
if you intend to change the settings, then its preferred that you have a wired connection to the router.
BTW, keep the routers admin password handy..
Cheers!!!
Feb 21, 2011 | Linksys Wireless-G WRT54G Router
How can i set interneton my phone nokia 7210 supernova?
For this first your network operator is to support this service if yes
send a request message to activate the internet service(for message format contact your service provider customer care)
Save the internet settings what they sent
Now go to Settings> Configuration>Default con settings>(select the name of your network operator) and Settings> Configuration> access point>(select the name of your network operator) and Settings> Configuration>active default in all apps>yes
Jan 27, 2011 | Lands Phones
Can't access my linksys on my laptops although I can on my desktop.
Hi ottawakids,
I see that you are having issues accessing your Linksys using your Laptops.
> First Check if the router is detected on the Laptops.
>If the Router is detected and un accessible you ill need to check if there are security settings in the Linksys Router.
>Check if the Linksys has a Network key, or check if the Router MAC address Filtering is turned ON the Router this can also prevent your laptops from accessing the Router.
>If all elsa fails try resetting the Router to defaults and start from scratch maybe some settings are incorrect, setting it to default will fix the issue of the Router not being detected.
I hope this helps.
Have a nice day.
mvincentc
Oct 20, 2010 | Linksys Wireless-G Broadband Router
Laptop connection problems to wireless router after reformat
Hi Drew,
I am assuming by access key your are referring to the pass phrase. The easiest way to approach this would be to use a cable to connect directly to the router from your laptop and confirm the wireless configuration on the router. You may have the pass phrase correct by the router is using WEP and your laptop is set to WPA or visa versa. Confirm the wireless configuration on the router then unplug the laptop from the router and change the configuration for you wireless settings on the laptop.
Apr 03, 2009 | Linksys Wireless-G Broadband Router
Adding another computer
try www.supportspace.com
100% free, but 100% qualfied experts to help you.
Oct 31, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
