I have a dv 2000 and when you turn it on it makes two load noises and it does not start up blank screen but the computer is running....
  • Boli May 11, 2010
    What are the loud noises? Bleeps? Bangs? Knocks? Ticks?
    if they are bleeps do they have a pattern?
    is the HD light acting normally (like its booting)
    Let me know...
    Matt
  • Eric Mitchell
    Eric Mitchell May 11, 2010
    Can you open the side of the pc and try to tell us where the sound is comming from
    President:
  • 2,692 Answers
Noises usually come from moving parts; Fans, and Hard drives are the most likly. I would open the side of the computer and determine which part was making the noise.
Posted on Dec 08, 2008
Hp pavilion dv 2000.Screen will not light up and I cannot hear any noise from the drive. Blue lights accross the top all are lit.
Perform the steps below :
1. disconect the ac adapter and remove the battery from the notebook.
2. press and hold the power button for 30 seconds
3. replace the battery and connect the ac adapter
4. Turn On the notebook
If the issue persists then reseat the memory modules of the notebook and check
This should resolve the issue
However, if the issue persists then it could be a hardware issue. Your notebook needs to be serviced
Jun 09, 2010 | Computers & Internet
Screen stays blank after start up. Grafic card?
take battery out then get rid of dust then restart it if still doesn't start make sure adaptor works correctly, if problem is still there its a computer error/bug
May 30, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
I have an E-Machine desktop PC that is failing to boot. It is running on windows 2000. When it starts booting, it says that one of the files needed for booting is missing. It further tells me to run a...
Windows 2000mag-glass_10x10.gif boot disks allow you to by-pass damaged Windows 2000 operating system files to get your computer up and running in a solid, stable configuration. You simply tell the computer to access the Windows 2000 codes necessary for start-up from your floppy disk drive rather than the hard drive. Creating the set of four boot disks is specific to this version of the operating system
  1. Step 1 Insert the Windows 2000 Professional CD into your computer's CD-ROM drive. Insert a formatted, blank diskette into the floppy disk drive. Have three additional formatted, blank diskettes standing by.
  2. Step 2 Click "Start" at the bottom left corner of your computer screen to open the start-up menu. This lists the start-up actions available for Windows 2000. Select "Run." The program then asks you to designate the drive, program, folder or file you want to open by either typing the destination or clicking "Browse," to select the destination from the Windows 2000 directory.
  3. Step 3 Click the "Browse" button at the bottom of the pop-up window. The PC's hard drivemag-glass_10x10.gif directory window appears.
  4. Step 4 Browse the computer's hard drive directory and select the CD-ROM drive to designate it as the destination you want to open. Click "OK" to open the CD-Rom drive. The folders and files saved on the Windows 2000 CD now appear in the directory format.
  5. Step 5 Select the "Bootdisk" folder. A directory of files appears.
  6. Step 6 Double-click the program file "Makeboot.exe," then click "OK" to launch the Windows 2000 boot disk maker program. The program checks that you have a formatted diskette in the floppy disk drive and then begins to make the boot disk.
  7. Step 7 Watch your screen as the process of making the boot disk progresses. The boot disk for Windows 2000 requires four diskettes. The program cues you to remove the first diskette and insert the second, and so on until all four diskettes are created and the boot disk making process is finished.
Nov 15, 2009 | E-Machines eMachines Desktop PC
RCA HDTV DLP 50'' TV Goes Blank!!!
The bulb went out, The clicking is the ballast trying to start the bulb
Jul 12, 2009 | Televison & Video
I have a HP dv 6000. I tryed to turn it on and
you need to restore the computer fo factory condition when the hp logo comes up right when u turn on the computer press the f11 key rapidly until it disappears. any questions you can email me at meanness628@aim.com
Jun 09, 2009 | HP Pavilion dv6000z Notebook
The screen go blank on my hp pavilon dv 2000. Why?
If you've checked the battery and power cables are connected properly then you've done as much as you can do, you'll need to take the laptop to a HP repair centre.
May 17, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Monitor Buzz on start -up
Try a different monitor or this monitor on a different computer. If it makes same noise on different machine or new monitor makes no noise on your machine you need a new one.
Dec 24, 2008 | Computers & Internet
URGENT HELP... i have broken my computer by OVERCLOCKING it...please help
First of all, it seems unlikely that you have actually broken anything.
Please look carefully at the options in the main setup menu (BIOS) after you press the DEL key... There sshould be an option to "loade defalut settings" or "load optimised settings"
If so select this option and F10 to save/exit and allow it to boot
Jun 29, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
