Question about Doro 550S Twin Cordless Phone
Handset 1 has stopped working. All I get is a beep from any key pressed, no dial tone
Handsets taken back to dealer. They fixed the problem
Posted on Dec 09, 2008
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
Speed dial help
To set speed dial numbers,with the handset down press the SPDL key(the key should flash)
enter in the 1 digit memory location code (1-9)
enter in the telephone number (up to 32 digits)
then lift and replace the handset. You should hear a confirmation tone and the SPDL key will stop flashing
To use pick up the handset, access a line and press SPDL and the location code (1-9)
Dec 22, 2009 | Inter-Tel Intertel 6123300 GLX Executive...
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Dialing
Use the following steps:
1. Press the program button on the handset.
2. Use the up/down arrow keys until you see dial mode.
3. Press the select button and use the up/down arrow keys to change it to pulse.
4. Press the select button. You will hear the phone beep which indicates it has been changed.
Dec 26, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Phone not ringing
Just recently the Innovage LED touch screen phone stopped ringing. It has worked perfectly as a home office phone since Oct. 2005. Cannot find anything in the tiny manual to correct this problem.
Dec 26, 2007 | Vtech VT-9118 Cordless Phone
Uniden 900MHz phone model EX17960A
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
Each pause counts as a digit.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
number has been stored.
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
Dialing a Stored Number
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
beep rapidly, and the phone will not dial.)
Nov 13, 2007 | Lands Phones
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
Doro 550S Twin Cordless Phone Logo
115 people viewed this question
Top Doro Lands Phones Experts
castletech
castletech
Greg Cann
Greg Cann
Gene Tuck
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
