Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Can't find the caps lock key on my siemens notebook
I have a siemens notebook. It doesn't have a caps lock that i can see. Do you know the functions to turn caps on / off.
thanks
darren
  • 282 Answers
It is always at the left of "A", i think it is not marked
Posted on Dec 08, 2008
  • anna_ingle Sep 10, 2010
    Yes - it is not marked but is the down arrow above the shift arrow. Thank you!
Does my siemens lifebook c6555 fujitsu have bluetooth?
Hello Darren,
Sorry, but it doesn't have a Bluetooth.
Nov 03, 2011 | Acer Aspire 5535-5050 Notebook
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
I CHANGED MY PASSWORD ON MY SIEMENS AMILO Si 1520 NOTEBOOK AND AM LOCKED OUT SINCE. I WANT TO KNOW WHERE IS THE CAPS LOCK STATUS SYMBOL ON THE KEYBOARD IN CASE CAPS LOCK WAS ON WHEN I CHANGED THE PASSWORD...
The Caps Lock button is normally to the left of the "A" key on the keyboard. I don't know that specific laptop, but there may be a light with the letter "A" in a padlock shown on the top of the keyboard, which will indicate the specific status of the caps lock.
Jul 26, 2011 | Fujitsu Siemens Amilo Si1520 Laptop...
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
I'M TRYING TO URN OFF CAPS LOCK ON MY FUJITSU LAP TOP LIFE BOOK A SERIES BUT CAN'TSEE A CAPS LOCK KEY?
Just press the key with arrow pointing down, it is above the left shift key.
Hope this will help!
Sep 10, 2010 | Fujitsu Siemens LifeBook S7010D Notebook
3 others indicators start blinking !
Dear friend,
Just follow the instruction.
1. After press power button for turn on press F8 key.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and enter.
Then just wait and watch what's is going. If the same problem then contact me again here in Fixya i will give you another way to solve the problem. Thanks.
Feb 03, 2010 | Fujitsu Siemens LifeBook S7020D Notebook
My fujitsu siemens amilo notebook screen black.
Check num lock key of laptop press num lock if numlock key is on and off when you press it then dispaly working fine only issue with screen resolution .
For that when you power up the computer press F8 key then enter in enable vga mode.
Then go to start menu ->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
But if num lock is constant when you press numlock key then you need to refix RAM memory.Open back cover of laptop then refix RAM memory.
Then check if still same issue then pull cmos cell from motherboard then check again if still same then try with another RAM .
When you power up the computer press F1 or F2 or "del" key if you are able to see bios screen then you not need to open back cover of laptop only make sure SATA is disabled and your harddrive is detected in bios.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Fujitsu Siemens Computers & Internet
No external wireless switch - how do I turn on wireless function on a fujitsu siemens laptop ?
I don't know that particular model, but in most laptops without a switch, there is a key on the keyboard that has a wireless little logo. The key usually works by pressing it simultaneously with the "f'n' (function) key. The wireless key is usually located at the first row of keys (the function keys, F1, F2 and so on). Hope that helps
Fred
Nov 26, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Keys on keyboard have locked
Try one of three keys, the num lock, the pause (break) key, and the Caps lock key.
Apr 26, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
606 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
