Question about Samsung DLP HL-P5663W 56" TV
TV not coming on
When switching on power switch, just makes a "tic, tic, tic, tic" sound, does not come on. Could this be moisture? As we live by the coast and TV was not switched on for about a week.
  • 105 Answers
Try check the horizontal output or flyback transformer..on the pcb board..sometime lizard die stuck below the pcb and tv shock when you switch it on
Posted on Dec 08, 2008
Tic tic tic sound when switced on no sound no video
:That sound usually means the power supply cannot start--due to an overload or overvoltage problem. Likely a few bad capacitors in feedback area or some short in horiz. area, possibly convergence chips if a tube set.
Mar 22, 2014 | Televison & Video
My tv turn on and off by itself
sound you may have a bad switch tic switch or bad power slppuy
Nov 18, 2013 | RCA D52130 52" Rear Projection Television
Philips TV making a strange clicking noise
A model number would be helpful to answer this but:
This clicking sounds (no pun) like either a mechanical relay in the set's power supply or possible arcing somewhere in the set.
These sets also have a shutdown feature that if engaged may sound like a tic-tic sound.
Let me know model number which is not indicated on this question here.
Jun 03, 2012 | Televison & Video
My rca tv will not turn on, But it makes a tic tic tic inside (no its not a bomb )when i push the on button. It is a ac/dc tv for my van.but my vcr works great when i hook it up to another tv. ...
your tv set has a bad relay short it trying to turn on but the relay then detects a fault and lets go (the tick tick sound) it will need to be looked at by a service tech to have the short found and repaired
please rank this advice if it helped
Feb 13, 2011 | RCA E13345 13" TV
My western digital 320 gig external hard drive stopped working all of a sudden. it has not been physically damaged. when plugged in the lights just blinks.
you told that it has not been pysically damaged than why light just blinks ok first you see the cable is in good condition. next plugin you hard disk to your computer and listen if any kind of sound coming through your hard disk (sound is like tee tic) if the sound out comes like what i said some way it stuck or damaged let me know if it works
Aug 12, 2010 | Western Digital (WD3200JS) 320 GB Hard...
Acer CRT Monitor with tic tac sound
1. horizontel transistor bad.
2. dry points on neck board.
3. cheak the power supply out put
4. LOT problem
Oct 13, 2008 | Computers & Internet
Tv cliking wont power up
The tic tic sound is a device called safety switch that keeps turning your TV off because an internal fault, such as a defective component or a wrong voltage is detected.
When is like that we say the tv is in protected mode.
Start unplugging TV power cord for one or two hours (it is called hard reset), this will drain power from tv and seset internal circuit, and sometimes can clear the error message, if the fault was only temporary.
If the problem does not go, probably some component inside the tv is faulty and may need to be replaced.
If the tv is one month old, it should be covered by warranty, call the phone number listed on the TV owner manual.
Sep 19, 2008 | Televison & Video
Toshiba 24AF41 24" TV Problem
If the problem does not go, then you have to troubleshoot the problem, probably some component inside the tv is faulty and may need to be replaced. If you want to do it yourself is better to buy the service manual.
Here you can buy parts and service manual.
If you need to call for repair you can use the phone number listed on the TV owner manual.
Sep 17, 2008 | Toshiba 24AF41 24" TV
Toshiba 24AF41 TV won't turn on
The tic tic sound is a device called safety switch that keeps turningyour TV off because an internal fault, such as a defective component ora wrong voltage is detected.
Start unplugging TV power cord for one or two hours (it is called hardreset), this will drain power from tv and seset internal circuit, andsometimes can clear the error message, if the fault was only temporary.
If the problem does not go, then you have to troubleshoot the problem,probably some component inside the tv is faulty and may need to bereplaced. If you want to do it yourself is better to buy the servicemanual.
Sep 03, 2007 | Toshiba 24AF41 24" TV
TV starts but Does Not show picture or no sound
The Tic Tic sound is a result of the high voltage shutdown circuit. Thats what the circuit does if theres a short in the Highvoltage sweep. like maybe a shorted horizontal output transistor??. The only way to really tell is go in and measure the start up voltage and if the Hivoltage comes up and shuts down its a fault in the shutdown or Hhv regulation circuit . if it dosent come up at all then the faults in the Horizontal sweep circuit . Hope this explains a bit? good luck
Jun 03, 2006 | Philips 28PW6006 28" TV
Samsung DLP HL-P5663W 56" TV Logo
121 people viewed this question
Henry  Thomas
Henry Thomas
