I have a cambridge audio A300 V2.0 amplifier that wont power up. i've checked for power at the switch and there is power and i've checked on the main board at the fuses but there is no power there, the fuses are ok so i've narrowed it down to a possible faulty transformer. how likely is this? any ideas would be gratefully received.
  • Seamus377 Jan 08, 2009
    as regards to the above, i have now sold the amp as faulty on ebay. thanks very much for the help though, much appreciated.
  • 85 Answers
Hi there get a multimeter place across mains input on transformer,FIRSTLY DISCONNECT AMP FROM MAINS,set your meter to contiuity ,if good you should get a low ohms reading (resistance),then check the secondaries (output of transformer) either 3 wires or four going into amp board..if readings acroos all wires are low ohms then transformer is good if one is open ,transformer has had it ...hope this helps
Posted on Jan 08, 2009
  • steve hall Jan 08, 2009
    If i remember rightly is this the cambridge with the gainclone chip on heatsink if so i would suspect this as faulty,as the transformer is bound to with stand more abuse,unless you had a thunder storm...
Cambridge audio 640a problem, olume goes to zero, I hear a little bang on speakers, light starts blinking!
This sounds like there's an overload in the main amp section. Often caused by a short-circuited device.
Oct 06, 2014 | Cambridge Audio Azur 640A Amplifier
When switching between inputs the sound often disappears from one or both of the speakers.
The that you're pushing is only local control switch same as remote control. So the main power is controlled by a relay inside the amplifier find that and using your remote control power it on observed the reaction if the relay is activated the measure the voltage if it going through the large capacitor. I hope this may help you.
Mar 04, 2013 | Cambridge Audio Azur 540A Amplifier
Cambridge audio Azur 540a repair
Open your amplifier then find the power relay inside push the power button and observed the relay if active. If so the measure the voltage on large capacitors. But if the relay is not active check the relay drive transistor and the blocking diode across the coil.
Oct 05, 2012 | Cambridge Audio Azur 540A Amplifier
I want to buy a trasformer for cambridge audio radio ammplifiare azur 540 v2
Cambridge Audio will be the only people that have spares
Check their website
Aug 26, 2010 | Cambridge Audio Azur 540A Amplifier
Since gales last week and flickering house lights for over 24 hours my cambridge audio a740 won't switch on. Any connection? Not the plug fuse. Help.
Just take the top off! As long as it's unpluged from the mains you wont hurt yourself.
This is perhaps what you are looking for:
Apr 04, 2010 | Cambridge Audio Azur 640P Amplifier
I need a psu for a Cambridge Audio Azur 540P phono preamp
any stepdown transformer rated 12V secondary with at least 0.5A rating would do (12V, 500mAmp). I know they said to use only the supplied power unit but hey that's business! but make sure whether your mains supply is 110Vac or 220Vac.
Mar 11, 2010 | Cambridge Audio Azur 540P Amplifier
Cambridge Audio Azur 340A amplifier,no sound
Start with the basics first. 1. With the amp on, in each imput socket plug a dual end phono cable in and touch the right and left plugs with your finger. You should get a buzz on each speaker. No buzz and the channel at that terminal is not working. If none of the terminals buzz. Then the amp is dead.
If some buzz and others not you have a pre-amp problem.
2: Amp Dead. Could be A power supply. B main pre-amp. C Power Amp.
The power supply check for a fuse.
The main pre-amp will only effect both channels if an IC controls both.
The Power Amp will again only loose both channels generally if it is an IC. It will be attached to a big heat sink and have lots of pins comming from it.
If it uses transistors for the main amp, you can check these with an Ohm meter. With the power off place the leads on each terminal of each transistor. If the meter goes fully over (like when you touch the leads together) each way it has shorted.
The thing to remember when repairing stereo amps. Is that the amp is two identical amps joined together. So what happens one side will happen on the other. If both channels don't work look for something that is common to both.
Good luck
PS never heard of 'cliperd'.
Sep 25, 2009 | Cambridge Audio Azur 340A 2-Channel...
245 people viewed this question
 Grubhead
Grubhead
