Question about Canon EOS Rebel Ti / 300V 35mm SLR Camera
Black Image I recently cleaned my Canon EOS Rebel and not long afterwards, I started having problems with proper exposure. When I try to take a photograph, only 1/3 of the frame actually shows the image. The rest of the picture is black. The image only shows at the top of the frame. I'm concerned that possibly the mirror is now out of sinc with the lens? However, upon closer inspection with the lens off, the mirror flips out of the way as it is designed to do. What could be causing my images to only record the top 1/3 of the frame? Thanks so much! Michelle
    Novelist:
  • 107 Answers
Are you taking these images with a flash? If so it is possible that you are shooting with a shutter speed which is too fast for flash photography. Anything faster then 1/125th (i think) on that camera with flash will produce the result you are describing. If this is without flash then the problem lies elsewhere. New flashes from canon have the capability to work with any shutter speed, but classic flashes only work properly at lower speeds. David Millier Advance Camera Repair
Posted on Feb 24, 2007
I have a canon eos 550d and i have been taking photos for the past 4 months or so and not a problem till date. but recently when a take a long exposure say 30 seconds or even 10, 15 seconds, after the...
Long exposures increase the amount of noise recorded in any digital image. Your camera uses blank frame subtractive noise reduction, like most others. After a long exposure with the shutter open, it temporarily records another similarly long exposure with the shutter closed. It then subtracts any hot pixels (noise) showing in the second image from the one you have just captured as they will overwhelmingly be in the same sensor locations on both images, regardless of any image data.
While all that is going on, your camera will be busy and unavailable for use, and that's exactly what it's trying to tell you.
If you don't want noise reduction then go into the camera menu and turn it off, but you will likely find that you spend far longer cleaning up your images afterwards.
Hope this has explained the issue clearly and that you are able to take a moment to rate my answer.
Jul 28, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Canon eos rebel xsi screen is black when taking a picture but shows picture afterwards..Menu works also so screen works but just black when trying to take a pic..
Set the shooting mode to a Creative Zone mode. Press MENU to enter the menu. Under the Setup tab, select [Live View function settings] then press SET. Select [Live View shoot] and press SET. Select [Enable] and press SET. Press MENU to exit the menu. Press SET. The image should now appear on the LCD instead of through the viewfinder.
Refer to "Live View Shooting," Chapter 5 in the manual for more details and the limitations of the LiveView mode.
Dec 26, 2010 | Canon EOS Rebel XSi Digital Camera
With my Canon EOS digital rebel xti i have the
I think it got exposure problem so need to adjsuted exposure and shutter speed or need to replace either top cover or finder unit i recommend to repaire with canon authorised centrre only.
Jul 02, 2010 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Half the picture is black
The black photo problem means the lens sensor is spoiled due to over exposure to heat. Its better to give it to cannon service centre. If your camera is under warranty period its well and good they will replcae the lense sensor for free of cost.
Thank you
Jun 10, 2010 | Canon EOS Rebel XSi Digital Camera
Why do my pictures come out black when they are developed
If we assume that the lens cap has been removed for the pictures, then you have other issues. The shutter is not opening. Why?
1. mechanical issue like something broken, bent, jumped out of the track.
solution: repair shop
2. electronic issue like exposure module died, misreading exposure sensor, flash not raising and firing, etc.
solution: repair shop.
Repair shop will also Clean, Lube and Adjust.
Apr 23, 2010 | Canon EOS Rebel X 35mm SLR Camera
Canon Rebel XS has stopped recording images...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS .
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Date on pictures taken and movie shooting on canon eos 400d
The EOS Digital Rebel, EOS Digital Rebel XT and EOS Digital Rebel XTi do not support stamping the date and time on the image.
It is not possible to record the date and time as part of the image at the time the picture is taken. However, the date and time is captured in the EXIF information of the image at the point of capture. It is possible to print the image with the date and time via printing software. Please see the documentation for the software package that you use for printing images for the proper procedure.
Apr 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Is my canon eos 400d broken?
This is a Digital SLR With SLR cameras you can only use the viewfinder because the image comesi nto the lens and up to the viewfinder via a mirror. When to take a pic the mirror flips up[usually with a crash] and the image goes to the CCD- afterwards you will get an image briefly in the LCD.
Sep 20, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon Digital Rebel XT, exposure
Use the bracket exposure method. or read the apeture off then up a stop.
Jun 05, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel Ti / 300V 35mm SLR Camera Logo
53 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
