NO SOUND COMING FROM TV
I HAVE PHILIPS MX6050D SURROUND SOUND SYSTEM. WITH ALL 5 SPEAKERS. THEY ARE NEW IM HAVING PROMBLEMS WITH YHE SOUND COMING OUT FROM THE TV. I NEED HELP SETTING IT UP OR WANT ELSE DO I NEED FOR THE SYSTEM. THANK HAPPY HOLIDAYS.
    Problem Solver:
  • 8 Answers
I have connected my new surround sound to the dvd player as everything else runs through it. Also found that it has a seperate switch for 5.1 surround sound (all the speakers active) and ordinary stereo. I'm unfamiliar with yours, but check for this switch, mine was hidden on the back of the base speaker.
Hope this helps
BB
Taliesin
Posted on Dec 09, 2008
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
No surrond sound
TV's are not sources of multichannel audio. The best you'll get is stereo analog. Get the best TV-related audio from the same source the TV gets it - in this case the Cable Box.
Feb 28, 2010 | Audio Players & Recorders
Remote Codes
Hi which universal remote do you own? You normally can find the codes on their helpdesk site. For philips:
http://www.urc.philips.com/
Jun 16, 2009 | Philips MX6050D System
Philips 32TA2800
The Way Im understanding your problem is,
it seems like you need to hook your rcas directly to the tv and switch the surround to aux or something similar to that.
Jun 14, 2009 | Philips 32PF7421D 32 in. LCD HDTV
How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
Jun 02, 2009 | Philips MX6050D System
NO SOUND FROM TV THROUGH THE SOUND SYSTEM SPEAKERS
All you need to do is follow the following directions on your TV and you will be on your way listening to your great Philips TV on your great Sony Surround Sound. You do not need to buy any other cords or anything else. Its just a setting on your TV that needs to be adjusted.
By the way, I have a Sony Home Thearte System DAV-HDX275 and I've had it for almost 8 months and its sounds good with my TV and Movies. The speakers are very cheap and it doesn't give you the sound you expect. So I came accross some Boston Accustics CR65's that are not sold anymore but they did run around $700 a peice. I am upgrading the Reciever very soon to a better qualtiy Reciever. This Surround Sound System is great for a starter Surround Sound System.
  1. Press MENU on the remote control and select TV settings >
  2. Press up or down to highlight a sound setting and press right to select the setting.
  3. Press up or down to adjust the setting, and press OK to confirm the change.
  4. Press Menu to exit.
You want to pick Incredible Surround, but if that does not work try them all. The Incredible Surround should do the trick because that switches it from the TV Speakers to the Surround Sound.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Have a Great One!
Mar 13, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
No sound from surround sound whilst tv on
YOU HAVE TO TURN VOLUME OFF ONTV AND PUT YOUR SURROUND SOUND ON AUX THATS HOW MINE WORKS
Jan 24, 2009 | Samsung HT-Q100 System
Cant install surround system to TV/DVD/XBOX360
Use audio out on t/v and plug that into input on the surround reciever
Dec 22, 2008 | Durabrand HT-3915 System
Only 2 of my 5 speakers are working
Press the SURR button until you get sound on all five speakers. If you don't get sound on all 5, there are a few possibilities:
1) the program you are watching only gets stereo sound or lower (only two or one speaker will play in this case)
2) you need to get a digital audio cable instead of using the red/white AV cable
3) a setting on the TV, cable, or satellite box needs to be changed to allow surround sound in full
Apr 30, 2007 | Philips MX3700D Digital Surround Sound...
127 people viewed this question
 Grubhead
Grubhead
