Question about Hoover Nextra HNL 3166 Z Front Load Washer
Machine will not switch on
When plugged in the red light does not display and despite changing fuse in plug there appears to be no power to the machine.
  • Hoover Master
  • 3,463 Answers
If you are certain the fuse is o/k then try it another socket that you know is working o/k, if still no lights. then could be faulty door lock.
At this popint I would suggest you call someone in.
Posted on Dec 08, 2008
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
Probleme de fonctionnement SC546
Check,clean and measurement the continuity of the fusing unit parts(heater lamps,thermistors,thermofuses) and reset the trouble code.Enter in the service mode :press total clear (yellow)key-107-and press and hold the clear (red)key more 4 second.If the SP mode appears to the display press the windows,open the front door and turn OFF the main power switch.Unplugged the machine,wait 10 seconds ,plugged on ,closed the front door and turn ON the power switch.
Oct 06, 2009 | Ricoh Office Equipment & Supplies
MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Despite being plugged in and the green LED light on, no display on printer
I have the same model (about a year old) but there are no lights visible on the back of my printer (neither red or green). Have you contacted the Lexmark tech advice website about this problem? They may take a few days to respond but there are numerous possibilities in trying to locate the fault (probably in the power circuitry) and it might have to take it to a repair shop to get it tested (if it is not under warranty).
Sep 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
Hoover Nextra HNL 3166 Z Front Load Washer Logo
250 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
