Question about Cooler Master Real Power 550 (RS550ACLY) 550-Watt Power Supply
Power Supply Problem
My power supply is making some weird sound, it gets louder over time.
Need some advice. Thanks in advance
  • compuwayne May 11, 2010
    Can you be more specifific of the sound?
  • 72 Answers
Hi there, If your psu is making sounds I would try blowing it out with a bit of air. If that doesn't help I would replace it since there are no servicable parts and with out properly discharging the HV components it is very dangerous to open the unit up.
Posted on Dec 08, 2008
Hello there! Got an old Philips plasma tv 42PF9945 with Samsung power supply LJ44-00049A that seems to be dead. LED's are off, there's no stdby voltage, all it's doing is a very silent sound...
Kris are you sure of that model number... That supply is most commonly found in a Philips 42FD9935/17 but they could have revived it for your model too I guess, neither were high-end units.
You would need several pieces of test equipment to properly check the supply and if you're not a tech I doubt you would have made such an investment. Best advice take to a qualified tech or just replace the supply. Try ModusLink, Tristate Module or Shop Jimmy for a replacement.
Jun 30, 2011 | Televison & Video
Oven won't come on and makes weird sound, Kenmore model 911-467881
hello,
this is an indication of weak wires from the connection of power supply over the range.
what you need to do to fix up this problem i to open up the range with the bass tools then trace down the wire to the power panel that distribute power to other part to function smell the wires to detect the born/weak wire from others then you make a replacement of the wire , or check on the fuse of the wire if is properly fix to it position with this the problem will be solve .
but if you did not have the technical skill or the knowledge to apply the explanation above then it is advice not to do it your self to avoid more damage on the range.
please before you can carry out this above information you will have to put off all form of power supply connected to the range.
thank you and thanks for using fixya.
Jun 13, 2010 | Kitchen Ranges
I have problem about over heating of my p4 procesor specialy in summers, my motherboard is 775i65G ... in summers the temp. of processor reaches 62 degrees and cpu fan runs on high rpm which results in...
all fans in time will get louder. The power supply unit has a fan and if you don't already have a fan on the CPU then you can add one to help cool it The fan in the power supply can be upgraded to a quieter one if need be. Any dust on in the case on on the circuit board will retain heat so getting some dry air and cleaning them should be performed. Be sure to ground yourself to the medal case when working with the case open.
May 11, 2010 | Asrock 775i65G Motherboard
My Viewsonic N4060W 40" LCD TV will not come on, i get a steady green light when power button is pushed but the screen is blank and no sound. My TV is 3 years old and just last year i had a somewhat...
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. If the tech installed a used power supply, it may be bad also. 3 years are typical for capacitors to go bad.
Nov 15, 2009 | ViewSonic NextVision N4060w 40 in. LCD...
My Daewoo TV screen just went all Blank n Black suddenly while it was running all fine Then this was accompanied by a strange clicking sound and now whenever i turn it on,it just shows nothing(blank...
The set has developed a short either in the power supply or the horizontal/high voltage circuit. The power supply makes a weird noise when it gets overloaded. This can get complicated so have a repair shop check it out for you. Thanks
Nov 01, 2009 | Daewoo DTQ-13V1FC TV
Samsung LN-S4051d power supply board
The replacement of the power supply is quite easy. You will have to remove the base if applicable and the back cover, once you remove it; you should see the power supply.
Click here to see how the power supply looks like and availability or Click here to find a cheaper one.
I can also repair your power supply. If you need further assistance you can write to jah2mil@hotmail.com
Jan 05, 2009 | Samsung LN-S4051D 40 in. LCD Television
Power supply hp 1020 lasserjet printer
You would need to order:
Engine power supply 220V to 240V (HP LJ 1020 printer) RM1-2316-000CN
You can call HP Support and order for the above RM... part number.
- Nikhil
Nov 12, 2008 | HP LaserJet 1020 Printer
Compaq Armada e500 refuses to start!
An immediate boot fail normally either indicates a flat cmos battery or a faulty processor. My advice is to take to a qualified repair shop, as notebook are not as easy to work with as desktops and finding the cmos battery alone can be a headache.
Nov 18, 2006 | Compaq Armada E500 Notebook
Cooler Master Real Power 550 (RS550ACLY) 550-Watt Power Supply Logo
69 people viewed this question
Top Cooler Master Computers & Internet Experts
Computer Links
Avishek Samaddar
Avishek Samaddar
Chris Larocque
Are you a Cooler Master Computer and Internet Expert? Answer questions, earn points and help others
