Question about Nokia N70 Cellular Phone
I have n70, drop in water 7 day's ago. Now it is dead. i checked with ufs, 1st boot is not ok.
    President:
  • 2,110 Answers
Your boot IC needs to be relaced...For that u have to go to nearest Nokia Care Center..
Posted on Dec 08, 2008
1202 nokia dead from water falling whaen i flash
hi,
clean your unit first using lacquer thinner,then blow it slightly by hot air...after doing that clean the pin out because if it water damage it must be corroded...what version of jaf you are using?if your version are not updated ,1202 is a sl3 (simlock 3) unit and not supported by lower version of jaf...much better if you use mx key dongle and ufs box as your interface (do not use jaf as your interface because it would be damage) or cyclone....and here is the procedure..
using easy cable ,connect the phone ,open mx key module ,select ufs interface ,dct4 then bus check...if the info of unit is showed ,put CNT ,MCU,PPM ..before flashing back up your phones rpl first ...then flash the phone...after flashing ,there is a possibility that the phones status is contact service ,dont worry just go to service ,imei and security then direct unlock...but be sure that your mx key is activated by dct4 plus unlocker...
in case the phone is not responding after cleaning ,reheat flash ic then repeat the procedure...i hope it will help you ,thanks for trusting fixya..
goodluck..
Jun 16, 2010 | Cell Phones
Tip
Great, but actually this isn't format the flash memory, if this is full format...
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
on May 12, 2010 | Nokia N70 Cellular Phone
Phone is dead after drop into water
Remove the battery and allow the unit to dry thourouhly. Take a hair dryer to it if need be. Once dry, reinsert the battery. The unit should boot up. Water doesn't tend to cause any lasting damage. Pop (soda) or wine or anything that is sugary will fry the unit though. Good-luck.
Dec 30, 2009 | RIM BlackBerry Curve 8310 Smartphone
Dead N70
first u chek ur on off swich&its print second re-hot booting ic&conect jaf or ufs
Jan 05, 2009 | Nokia N70 Cellular Phone
Handset Nokia N70 Dead
yeah it still have chances, u take it sooner to technician don't wait for long, if much days will pass lesser will be the chance that ur phone will work again.so take it to technician so it can be repaired on time.
Feb 28, 2008 | Nokia N70 Cellular Phone
N70 blanking(all display white )
It looks that your N70 has a booting problem. Your phone wasn't booting. Usually the boot IC goes bad and needs t be replaced. You have complicated your problem by changing the glass IC's. This surely wasn't your problem. I'm not sure if you have replaced them correctly though. If you have a digital multimeter than check your phone across the battery terminals. Keep the meter on 'Continuity' which also shows a 'Diode' symbol and check ur phone .Between +ve to grnd, one side, the meter shd show around 370 ohms and reversing the polarity of the meter across the same terminals of the phone the meter shd show a reading similar to a capacitor discharge action towards infinity. Now if these readings do not show, then the phone has a 'shorting' somewhere. I suggest u take your phone to a technician he may be in a position to kick start it back to life.....................
Jan 17, 2008 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
