Question about Ovens
Replaced oven heating element, now trips electric
I have a Candy Convex oven which with a problem. The grill worked and the oven light but no heat from the oven. Purchased new oven heating element, opened up oven and removed old emement. Element was badly distorted and split in one part so felt condifent this was the cuae of the fault. Fitted new element but when I turned on the oven, it tripped the circuit breaker. I tried again but it stayed on for about a minute and was heating ok, but then tripped the circuit breaker again. I thought I would smell burning coming from the oven also when I tested it. We took apart the oven several times ensuring that all wires were put back correctly and that no wires were trapped and that nothing was out of place but still has the same problem. Please can somebody point me in the right direction.
cheers
Are you sure you have the correct element for that oven. espares,v.good... or poss spares2you.. spares2go.
Posted on Sep 30, 2011
  • Ovens Master
  • 3,463 Answers
Disconnect the new heater and try it again , if it still trips then your problem is elsewhere, if it does not trip, then it points to the new element being faulty.
If it is fan assisted make sure the fan is running o/k.
Hope this helps.
Please leave feedback.
Thanks.
Posted on Dec 08, 2008
Heating elements in fan oven not working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 26, 2011 | Smeg Ovens
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jan 14, 2011 | Smeg Ovens
Oven fan not working so oven not heating up
have the motor checked and replaced if no runnig the oven will not heat as it is a safty measure
on moter the fan blade could have been loose, the motor bearings could be worn out or the fan motor gone kaput
Jun 15, 2010 | Zanussi ZBQ665 Electric Single Oven
When i switch the oven on the oven trips the main circuit. the oven used to work normal then it started to trip out after it had been on for a long period. you could leeave it off for 10 mins then it would...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Feb 15, 2010 | Candy F248P Electric Single Oven
Oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Jan 17, 2010 | Ovens
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Zanussi oven not heating
The fan element was not working, bought one on ebay replaced it works ok now. Fairly easy to fix remove inside back cover, 4 screws, you will see the element remove 3 screws pull out element pull off 2 connectors careful not to lose the wires back through the holes. replace in reverse order.
Jul 12, 2008 | Zanussi ZHQ575 Electric Double Oven
SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
Dec 10, 2007 | Ovens
Ovens Logo
333 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
