Question about Vacuums
Dyson losing suction and air!
Hi
i have been searching for someone with a similar problem to mine but to no avail.
there seems to be a LOT of air coming out of the housing where the cable is stored in the wheel (DC05). Is this normal? If not is there something I can do that might stop the air coming out?
many thanks
  • iankerry Dec 08, 2008
    thanks for replying.
    I did email dyson directly, and was pleasantly surprised to receive a telehpone call from them. Great customer service. For £65 i can get an engineer to call who will replace any parts necessary all inclusive.
  • 125 Answers
It has a crackesd housing, not normal. there arent any repair parts out there unfortunately
these are cheaply built vacuums.
dont believe everything you see on television
after years of repairs, my favorite is Panasonic, or Metropolitan
Posted on Dec 08, 2008
Hi I have only just bought my Dyson DC27 and it works perfectly on the flat, however when I take the wand out it instantly squashes the hose flat with the suction and therefore loses a lot of suction. ...
The warm air coming from beneath the clear bin is the motor exhaust, where filtered air is expelled back into the room. It's a feature of the cleaner's design, and nothing to be concerned about.
You may find that the new cleaner's hose is rather stiff to use at first due to the powerful suction. However, you should find that it will loosen up with use. You can expedite the process by stretching the hose out to its full length whilst someone else holds the cleaner in place.
If you have any further questions about using or maintaining your DC27, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US), so one of our experts can provide further assistance.
Kind regards,
Jack
Dyson Customer Service
Jul 21, 2011 | Dyson DC21 Bagless Canister Cyclonic...
My dyson vacuum cleaner doesn't seem to have the same suction power it used to. I have cleaned out the canister and have taken apart the vacuum head (for cleaning carpets) and it doesn't seem to be...
Hello, this is Ava with Think Crucial.
Most of the time the reason why the vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this.
You can purchase a wide variety of high-quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 08, 2011 | Vacuums
Loss of suction?
Mine was doing something similar. When standing upright, suction was strong through the hose. When I lowered the handle to sweep the floor, the bar underneath would spin, but the suction seemed horrible and the dirt inside the window wasn't spinning/cycloning like it used to. I called Dyson Support and they had me lay the vacuum on it's left side. Now look underneath and you'll see a clear hose, one end connected to the upper part of the vacuum and the other to the lower. I removed the tube and it was completely clogged, especially at the point that it connects to the bottom part of the vaccum. After that I reconnect and it sucks like the day I got it. Dyson support is still sending me a new "internal hose" but I don't think I need it.
May 25, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Dyson D17 won't work while upright.
check and make sure you have the gasket installed correctly that goes on the center of the cyclone and seals against the canister trap door. If this is backwards, you can lose a lot of suction and it will plug your permanent filter quickly.
Sep 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson has lost suction and loud noise from base(?),
I had the same problem, from right out of the box. Now that I just threw mine out, I see this site that indicates there's a fix for it:
http://ths.gardenweb.com/forums/load/cleaning/msg0415060828462.html
And search for other sites isung "dyson grinding" or similar.
Since I was an early adopter (had one as soon as they came stateside), I did not have the benefit of countless others having the same problem, I just attributed it to a junky design, since so much else about this vacuum was poorly designed, like the seals, hoses, etc.
Give them a call, and good luck! I might rescue mine from the heap and do the same.
Apr 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC7 full Kit, with one belt does not get suction to head.
Not absolutely sure about this, so your feedback will be very welcome.
What follows applies to the DC14, which I think is similar in this respect:
Stand behind the machine, holding the handle at a 45 degree angle. Locate and remove the airway inspection valve (bottom of handle, right side). Where the valve plugs in there is a square plastic moulding that should slide up and down. Snap that square plastic piece up towards the ceiling. After it snaps into place, the machine should stand upright.
Good luck, and please let me know how you get on!
Mar 21, 2009 | Dyson DC07 All Floors Bagless Upright...
Dyson DC 14 Animal is not sucking dirt
our dyson had the same trouble,we unclogged it by taking the bottom air valve off by the base and out the obstuctions above in the handle
Dec 24, 2007 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson dc07 suction when upright but no suction when tilted in operate position
Not sure if this will definitely fix the problem.......but here goes for anyone with the same problem....spoke to Dyson helpdesk today following some online research i did yesterday. The 'internet' view is that there is a design fault with the cyclone chamber of the DC07 and that older models need it replaced. Mine is a 2003 model and Dyson asked me if there was a Number 1 stamped on the back of the cyclone housing near where the air duct connects to the hoover body....there wasn't. They then said they would send out a new cyclone chamber free of charge (I bought my model as reconditioned in 2007 from an approved Dyson dealer, so no Dyson warranty) suggesting they are aware of a problem. Advice on another site by someone who was also sent a new cyclone is that the holes in the early cyclones were too small and got easily clogged. I'm now waiting for my new part and will see if that fixes it.
very strange though - my old DC01 was a far better model from what I have seen so far of the DC07 - they seem to have gone backwards in design & reliability.
Very impressed with the service from their helpdesk though - they put other companies to shame with their speed of answering the phone and the ability to actually talk to someone not just a series of automated menus - well done Dyson for that at least - I'll reserve judgement on the DC07!!!.
Dec 24, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
