Question about Minolta Office Equipment & Supplies
We have a Minolta PagePro 9100 black and white laser printer. It's had a couple of media jams in the fuser but even after clearing the jam the message 'media jam fuser' won't go away. It's been turned off all weekend but has not reset itself. We think it might be electronic/faulty sensor?
  • Minolta Master
  • 6,168 Answers
SOURCE: Media Jam- Fuser
thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Posted on Jan 10, 2008
Nicolomd
  • 84 Answers
SOURCE: I want cd for instale KONCA MINOLTA PAGEPRO 1300W (driver)
Try this driver (choose the operation system)
http://crm01.konicaminolta.eu/openmind/technic/kmpsdwl.nsf/psearch?OpenForm&ch=PRI&dist=BPE&ui=en&dg=sw&prod=PagePro%201300W&dsg=&os=&lang=&ml=0&rid=41256849005CE173&sub=Printer%20Driver&pcat=B%2FW%20Printer&pcc=1
don't forget to vote!!!
Posted on Jan 19, 2008
  • 8 Answers
SOURCE: Pagr pro 9100 and Mac OSx 10.5.1
I am not clear with the quarry you ask but what I understand that you can print larger the A4.so in all Konica Minolta printers which I have used we must specify the paper size before printing in the printer properties and confirm that the same paper size we have putt in the printer’s tray. if more then one trays and installed in the printer the printer can print all available paper size without specify them. But spouse if you send a legal size print to the printer and there in no legal size paper in the paper tray then it will show a error.
What I think it is paper size issues please check it and make sure the trays are fixed to the size which you putt in.
Posted on Jan 25, 2008
SOURCE: minolta 1400 pagepro there is no drivers for
please help me to connect my kodak esp printer.
Posted on Aug 13, 2009
SOURCE: Konica Minolta PagePro 1350W Laser Printer won't print anymore
You have to be sure that you are connecting the printer in exact the same USB port. If you are connecting to a different port and not to the one from was disconnected, the Windows is installing another copy of your printer. Check this, I believe this is the solution to your problem.
Posted on Aug 23, 2009
How to install PagePro 9100 on Maverick
The machine is very old. Before Konica and Minolta merged. QMS was under Minolta. Don't believe you can get the drivers but try Konicaminolta Web site.
Sep 13, 2014 | Minolta QMS PagePro 9100 Laser Printer
Printer reports Media Jam Fuser when there is none
If you know how to dismantle the printer that will be better so you can clean the entire printer and check all the possible things that maight causing the paper jam....
Aug 14, 2008 | Minolta QMS PagePro 9100 Laser Printer
Media jam upper tray
Clean the rollers, ensure the paper type matches in the draw with printer properties. Check the paper (media) guides.
Feb 06, 2014 | Minolta QMS PagePro 9100 Laser Printer
Media jam transport
Same as a paper jam. Media is paper. So check for paper also check that any acturators and or sensors in the paper path are ok.
Feb 15, 2013 | Minolta QMS PagePro 9100 Laser Printer
I HAVE A MEDIA JAM FUSER PROBLEM, WAHT CAN I DO TO FIX IT?
Well a media jam is a paper jam remove the paper. Remove the transfer belt or the fuser what ever is required. chk web site for owners manual. Self Help Product Support Konica Minolta Business Solutions Inc
Aug 25, 2011 | Minolta 2430DL Color Laser Printer
Printer says media jam transport no jam found or bad switch that I can find
Attentively examine the sensors of the passing of the paper. 1. The Sensor of the arrival of the paper. 2.датчик passings , he in medium device. 3. Datchih leaving the paper. Usually can be обрыванеи papers, or more often when paper извлкают damage the sensor and he comes out of its place. You should visual to make sure that sensor in its full tilt and есл no correct (it).
Sep 28, 2009 | Minolta QMS PagePro 9100 Laser Printer
In Konica Minolta 2430dk, I had a media jam in the fuser. I cleared the visible paper, but there is still some stuck inside the fuser that is impossible to clear (I can't get my fingers to it), so printer...
The only solution is to take the fuser unit out of the printer, then you may be able to manually rotate the rollers to clear the jam. If there are any marks or scratches on the fuser rollers, you will need to replace the fuser unit, or you will get marks on your prints
Jun 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
Media Jam - Fuser Error
if the paper comes out and you get still this message, then probably you have a wrong paper format or fusing unit solenoid is stuck.
Aug 09, 2008 | Minolta 2430DL Color Laser Printer
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
