Hotpoint BDW129 - Lights continually flashing
Hi
My Hotpoint BWD129 lights continually flash preventing the machine to be used for anything. The DRYING light is flashing along with all types.
Ive opened the door and there is still water in the bottom of the drum
I've tried switching it off/on. Left it for several hrs etc.
  • 90 Answers
SOURCE: Hotpoint bwd129
I'm not familiar with this machine with out a picture, but does it have a control knob that would allow you to advance through the cycles? If so you should be able to go to a spin cycle and empty the unit. How long did you leave it unplugged? Sometimes it requires several minutes to loose its memory. If not you may need to empty the water manually as it may be a fail safe to keep you from getting the floor all wet. Take a bucket and lift the drain hose out of the house drain pipe and lower it into the bucket to empty. It may take several trips. This will not work unless the hose comes out of the bottom of the machine which I think yours does. Once empty try plugging the unit back in and see if that helps. If not the main control processor may have taken a voltage spike and has suffered irreversable damage and will need to be replaced. Please give me more info..
Posted on Feb 03, 2008
SOURCE: Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Posted on Dec 22, 2008
SOURCE: There is a series of
hi there,
i had similar problem . there is a blockage in the fllter , probably a small sock. the filter is at bottom right hand at front of machine .
turn anticlockwise to open.
regards
big eck
Posted on Jan 31, 2009
SOURCE: HOTPOINT BWD129
i have a hotpoint first edition 1200, and theres a banging noise when it spins, sounds like something inside stuck on the drum?
Posted on Mar 14, 2009
ginko
  • 19396 Answers
SOURCE: hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 16, 2009
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
I have a Hotpoint BWM129 washing machine and the Delay start and Superwash lights are flashing. Can anyone explain what fault code this is? The door locked light is also on.
Manual says to unplug maching from wall for at least 40 seconds to a minute. This will reset the unit. If that does not work you will need to call a service tech.
Jan 30, 2015 | Hotpoint Bwd12, Bwd129, Bwm129 Washing...
My washing machine wont start up all flashing lights on LED's Basically i click on the start button and all the LED's start flashing continuously. Initially it flashed for about 3 minutes and then i could...
Machine is finding a problem during the initial diagnostucs on startup. Check for damp, condensation on the carbon brushes or worn brushes. Also check for earth leakage.
Dec 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Oct 13, 2008 | QuietLine WD-9900 Front Load Washer /...
There is a series of lights flashing on my Hotpoint BWD129 washer/drier. The lights flashing are the 'door locked' light as well as the 'super wash' and '1200/600' lights. This coincides with the machine...
hi there,
regards
big eck
Aug 04, 2008 | Hotpoint Washing Machines
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
I have a BWD 129 Hotpoint intagrated washer dryer and lights 1 2 and 4 are flashing what does this mean and do I need a new machine it will not do a drying cycle?
Filter blocked, disconnect hose from under sink connection and drain into bucket. Hotpoint does not want you to change filter, contact Service Engineer.
Apr 03, 2008 | Washing Machines
Washing Machines Logo
349 people viewed this question
Top Washing Machines Experts
