My washing machine starts its cycle, but when it gets to the drum going around it stops working as though the drum will not spin
    Scholar:
  • 81 Answers
Hi!
Welcome to Fixya,
please off the power and open the back case of your washing machine and turn on to check if motor is running and the belt is in tension.
if the belt not already in tension, then buy for replacement with the same spec.
if the motor not working, you need a qualified technician in your area to check the problem.
or If you need further assistance to do it with your self, so let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
aclamonte
Posted on Dec 08, 2008
3 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: No longer rinses or fast spins...although drum does go round slowly...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Posted on May 05, 2008
  • 132 Answers
SOURCE: wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Posted on Jul 05, 2009
Washing machine
check lid isolation switch. check for balance of clothes. I would go for the lid switch first. The balance second as if it starts to spin and wobbles violently it will switch itself off to prevent damage and you will have to move the clothes around to balance the drum.
May 18, 2013 | Washing Machines
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Apr 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wash cycle and spin
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
WASHES BUT WILL NOT SPIN
If your washer pumped out the water then your motor and water pump are both still working. Your washer has many sets seals and bearings that could have gone bad. This problem happened to my washer in the past also and i was able to just spin the drum around a few times and then shut the lid on the spin cycle. It started spinning slow but was able to make speed quickly. The oil seal on the gear case did start leaking though. This should be a cheap fix that could be done by most people with some mechanical ability.
Feb 14, 2008 | Washing Machines
Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Apr 01, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
