Question about Radio Communications
My vertext standard vx-424 when i tap the turn on knob the radio shuts off then back on
  • Radio Commun... Master
  • 1,654 Answers
You have either a bad volume potentiometer or a bad solder connection to the component board. The radio is in need of repair.
Posted on Dec 08, 2008
How to reset vertex 426
Maybe this will help: Vertex standard vx-426 owner manual Download Vertex standard vx-426 owner manual :
https://vwjqovoy.files.wordpress.com/2015/08/vertex-standard-vx-426-owner-manual.pdf
Jan 31, 2017 | Vertex Radio Communications
Trc 424 with tx mod coming out of the internal speaker.
check for a resistor soldered across the P.A. jack and external speaker jack (solder side of the board) if you see one, remove it
Nov 17, 2013 | Radio Communications
Ce-82 For Vx-2100 Vx-2200
The software changed to add Narrowband programming. 3.01 is fairly new, what issue are you having? Do NOT run this on Windows 8, even Win 7 has problems.
Apr 20, 2013 | Vertex Cd Standard Ce-82 For Vx-2100...
Trying to determine the cause of intermittent signal from microphone on a vx 4600 radio
Yes, short or lack of a good ground. It could also be the cord attached to the mic. The mic itself should provide the needed feedback to the radio that a mic is plugged in. Do you have anything connected to the accessory jack in the back of the radio? That can cause the same issue.
Apr 07, 2013 | Vertex Standard VX-4600-G7-45 PKG-1 UHF...
Programming cable for vx-230 how it is made
Do you have the factory software and programming cable now? You must have those in order to program the radio on a computer.
Jan 25, 2013 | Vertex Vx-230 Series Radio Programming...
Vertex 1700 Locked to Ch1 on 1.700 MHz (not dial lock)
Great news, I'm happy you've got the solution to your query.
cheers,
Peter
Nov 19, 2012 | Vertex Standard VX-1700 FCCver. HF...
Sound volume
hi there are 2 options for this: 1) if its a anlog knob then the AMP inside is gone bad... 2) if its a digital knob then it is preesed constantly and there for raising the volume level try disassemble the system and making the spring knob more efective good luck
Dec 28, 2005 | RCA RS2652 Shelf System
Radio Communications Logo
56 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
