DAM0007 Hi, I am new to Business Objects and have created a reports using BO XI R2. I have 2 environments setup one in Windows(client) and the other in Solaris(server). Both are not in the same network. i have developed a DESKI report on Windows environment and have deployed the same on Solaris. On refresh of the report on the server i get the following error: The Following query is not refreshed(DMA0007). Also on trying to run the report on selecting the appropriate prompt value i get the error '' connection required to refresh the document is unavailable(DA0004)''. Any idea what is to be done??
3 Suggested Answers
  • 12 Answers
SOURCE: When trying to refresh a Business Objects error... DMA0007
If changes have been made to the universe it may well be that in Deski you're using a local copy of it,
I would first advise exporting the universe to the repository (cms ) and having another go in Infoview just to ensure that the same copy of the universe is being used.
If it still fails, you will need access to the Business Objects server as it could well be that the connection on the server is either missing, incorrect or using a different version of middleware.
The fastest way to check on the server, is to launch Deski directly on the server and import the report > refresh it and see if you get the error.
If so then we know that it's a connectivity issue.
Posted on Mar 14, 2009
MohitdTechno
  • 43 Answers
SOURCE: How to add multiple data sources?
The following links may be very useful for you
http://www.c-sharpcorner.com/UploadFile/mahesh/MultipleDataSourceReport08232006225431PM/MultipleDataSourceReport.aspx
http://www.softguide.com/pj/2762/crystal-reports-developer-edition.htm
http://www.vtc.com/products/Crystal-Reports-XI-Beginner-Tutorials.htm
If you like the solution
plz vote for me
With Regards
Mohit
Posted on Oct 22, 2009
Dear specialists, I've faced with error with BO Report: The excel file is updating every 15 minutes, but since yesterday BO creates corrupted excel file. Status of appropriate schedule:...
Excel unable to read file is able to resolve Excel repair worksheets, fonts, formulas, cells, columns, rows and etc. Software gives back excel data crashed by any reasons: viruses, incorrect actions anti-virus software, hard drive failures. Tool has the compatibility with Windows 98 and higher. Its interface doesn't require special skills and is simple for novices.
Jun 03, 2011 | Business Objects BusinessObjects...
Hi all i am not able to open my admin console. when i try to open in my server itself it raise a 00070 error and some other machines it raise a 00071 error. Pls make me clear why this kind of error...
I believe BO console uses Java runtime environment. Not sure which version of Java is compatible with the version of BO that you have.
If you can find out then compare with the version of Java RE on your machines. You may have to revert Java to the appropriate version. The version you need should be available from the website.
Oct 29, 2009 | Business Objects BusinessObjects...
plz vote for me
With Regards
Mohit
Oct 21, 2009 | Business Objects Crystal Reports XI...
BusObj error BOL #109 The following data providers have not been successfully refreshed: xxxxx (DMA0007) (scrbsrtdkgls024). In this error xxxxx represent for what? and what is scrbsrtkgls024?
From the error you've posted I would guess here that you're attempting to refresh a full client report via webintelligence or via a schedule.
Does the report refresh correctly on your client machine?
If so then it's likely that the connectivity setup on the server is incorrect.
Are you using Oracle?
Which version of Business Objects?
Jun 24, 2009 | Business Objects BusinessObjects...
BO Error (DMA0007)
This error - DMA0007 is generally a connectivity issue, or you are attempting to refresh a report that uses a local dataprovider , e.g. an Excel workbook.
Which version of Business Objects are you using?
How are you refreshing the report.. manually / via infoview / scheduled in XIR2 or via BCA?
Jun 15, 2009 | Business Objects BusinessObjects...
Business Objects Context problem
Why not add a simple derived table in the universe, e.g.
select 1 as 1
Then place a self restricting join on the derived table
Then add the self restricting join to both contexts
Create an object from the derived table and add to query...
this should prompt users for a context.
JB
May 12, 2008 | Business Objects BusinessObjects...
Disappearing Command Bar in Business Objects 5.1
Hi monismitch,
I'm assuming that you're using Business Objects full client, in which case we can simply reset your user preferences.
Workflow on your machine
1. Start > Run > Type Regedit -- this will bring up your registry
2. Browse to:
HKEY_CURRENT_USER\Software\Business Objects\Suite 11.5\default\BusinessObjects\ "username" user prefs
3. Delete only the key that shows your username
4. Note - the above registry path is for BO XIR2, for version 6 the version name will be slightly different.
Log back into Business Objects and rerun the report.
Mar 19, 2008 | Business Objects BusinessObjects...
C0000005 'EXCEPTION-ACCESS VIOLATION' call stack at module... error
This is either due to a corrupt report or a bug - depending on the version of BO that you're using.
To rule out a corrupt report, if you rebuild it does the error still occur?
Sep 10, 2007 | Business Objects Computers & Internet
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
