Question about PPI DCX-1500.1 Car Audio Amplifier
Blowing fuses under hood but nothing looks smoked in the amp
I am blowing 80 amp fuses when the amp turns on. I have disconnected subs, RCA's, and just have 4 gauge for power, 2 (or dual) 8 gauge for ground, and a remote turn on connected. If I disconnect the remote turn on and connect power and ground, it doesn't blow the fuse. Its not until it recieves a signal from the remote turn on. I have everything turned down on the amp, and like the subject says, nothing looks smoked in the amp.
You need a bigger fuse holder. Your amp is tryin to take more than 80 amps. Mine did the same thing and in theory it needs 180 amps at full power. Upgrade the fuse block and it will stop
Posted on Oct 06, 2008
    Novelist:
    Champion:
  • 219 Answers
Sounds like the amp is fried, most likley in one or both of the output sections. Good luck.
Posted on Feb 22, 2007
Why is there no power to starter or lights?
What smoked ,the Fuse? SHORT ? what fuse ? Main fuse - explain ? Still no fire ? Doesn't crank , no spark ,what ? Does the starter spin the engine when you turn the key to the start position ? a crank no start condition . or a no crank - no start ! Check fuse F1 80 amp in the under hood fuse box.
Nov 18, 2015 | Ford Contour Cars & Trucks
Why does my Definitive Pro Sub 1000 keep blowing fuses the second I put them in?
Sounds like the amp is shoot.
Never power on the amp without speaker connected.
May 24, 2014 | Definitive Audio Players & Recorders
Blowing 50 amp fuse under hood in 2002 crown vic
To blow a fifty amp fuse would take a major short circuit, referred to as a 'dead short' this means that a wire with 12 volts positive (+) is in direct contact with an Earth (-). If you follow the path of the power you will find where this is happening. sometimes you may need to temporarily disconnect some contacts
Jan 31, 2014 | Ford Crown Victoria Cars & Trucks
I have a neon that wont start. It quit on me yesterday and got it started while going down the 1 mile later was at the house! I've checked every thing! Today I check the fuses under the hood and found a 20...
You will have to check the start switch.If its smoking you have a short in it which could cause a fire.Thats why it keeps blowing the fuse its a short in the switch.
Mar 11, 2011 | 2000 Plymouth Neon
THE AMP TURNS ON BUT THE FUSE UNDER THE HOOD KEEPS BLOWING and the sub wont turn on but the amp turns on
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Please use volt meter to test correct voltage and ohm feas ng on speakers. .A thumbs up would be greatly appreciated if this answer is helpful to you. amp-turns-but-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Jan 16, 2011 | MTX X Thunder 1000XD Car Amp
My stop hazard fuse keeps blowing on my 95 chevrolet k2500 Cheyenne. I do not have cruise control. i have disconnected the break relay and my turn/hazard switch. It still blows, yet when i unplug my break...
check the AMPS for all your fuses sometime a low amps fuse in the wrong slot can blow otherones. also sometime you can increase the fuse that keep blowing. try that first if that do not work you might need to run and electrican test on your fuse box to check if you have a short. also check your fuseable link on the fuse panel under the hood.
Nov 13, 2010 | 1995 Chevrolet K2500
Proform 570 blowing fuse
there are generally two control boards, I am assuming you looked at the lower one. I would first disconnect the power leads at the board and see if it still blows the circuit breaker (fuse?). If it does the check wiring for short. If OK then reconnect power leads and then disconnect all other wires (plug-ins) to the board and try again, each time plug a connection in and retry. (remember to disconnect power each time). I have a feeling the smoke got let out of this lower board and may need replacement. hope this helps
www.twincityrepair.com
Mar 01, 2009 | Proform 575 Crosstrainer Treadmill
Amp not working
If the fuse only blows after remote voltage is applied, it likely has shorted output transistors.
You should confirm that nothing external is causing this by disconnecting the speaker wires from the amplifier's speaker terminals and disconnecting the RCA cables from the jacks.
What make/model amp is this?
May 01, 2008 | Car Audio & Video
Fuse keeps blowing?
The fuse is a protective device. Fuses dont blow unless the amp ( in your case ) is drawing too much current. DO NOT put a bigger fuse in. Obviously, there is a problem with the amplifier inside the sub. If the sub is under warranty, send it in for repair to an authorized warranty depot. If not it's not under warranty, then take it to the authorized warranty depot anyway. Why ? because they will have the schematics ( electrical diagrams ) to troubleshoot the unit quickly and it may be a common problem. If it is a common problem, the factory may have released a modification and possibly it could be covered under warranty under a factory 'goodwill' program. Good luck. Rob
Mar 03, 2008 | Energry Speakers Energy Speakers S8.3...
PPI DCX-1500.1 Car Audio Amplifier Logo
95 people viewed this question
Top PPI Car Audio & Video Experts
Mike Duncan
Mike Duncan
Jose Velazquez
Jose Velazquez
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
