Question about Lenovo 3000 C200 Notebook
When you turn on my lenovo laptop there is no display
I plugged a usb my computer told me to to reboot and i did when it oned my laptop it said that i have a missing operating system. and it when black. i kept rebooting but there as no display it was still all black
  • Nicolas
    Nicolas May 11, 2010
    What was it that you connected in the usb-port?
  • 282 Answers
Your computer might be looking for the operating system on your usb,try to disconnect the battery and ac adapater and put it back again,reboot he computer,if problem persist,you might need to go to the bios or setup screen,usually you can go there either by F2 or delete when you turn it on,go to the boot order/boot sequence and make sure that your hard drive is on the number one list,otherwise,you need to change the order so it wont read the usb before it loads windows
Posted on Dec 08, 2008
I recently purchased a Lenovo All in One wireless computer. I've plugged in the USB cable as per instructions but my X4650 printer will still not print.
Have you installed the printer drivers? Is the printer power turned on before plugging the USB cable into the computer? You could have a bad cable. Try a different cable.
Dec 13, 2014 | Lexmark X4690 Wireless InkJet Printer
Flash drive unrecognized
Remove the USB, shut down, unplug, remove battery, plug in, Reboot the machine, insert the USB, you didn't supply the Lenovo Model or the OS? Without knowing your OS or laptop model, the size of the USB drive may make a difference. Do ALL your Windows and Lenovo updates.
Feb 13, 2013 | Lenovo Computers & Internet
How can i open my webcam
Open your computer's web browser.
Type following URL into your browser's address bar:
"http://www-307.ibm.com/pc/support/site.wss/MIGR-66973.html"
Press enter and your browser will open the Lenovo USB webcam download page.
or
Click the "lenovousbwebcam.exe" link to save the driver installation file to your computer.
Double-click the downloaded EXE file, and follow the on-screen prompts to install your Lenovo webcam.
Click the "mediaonegallery.exe" link to save the Lenovo Media One Gallery application installation file to your computer.
Double-click the EXE file, and follow the on-screen prompts to install the Media One Gallery application for use with your Lenovo USB webcam.
Restart your computer to save changes.
When you reboot your computer you can click the Media One Gallery shortcut to use your webcam
hope this helps
Oct 05, 2012 | Lenovo IdeaPad S9 S9e S10 S10e MSI Wind...
Give my answer
or
hope this helps
Oct 03, 2012 | Lenovo Computers & Internet
I need to install a web cam on laptop so you give its setup
or
hope this helps
Oct 03, 2012 | Lenovo 13N7107 LAPTOP LCD SCREEN 14.1"...
I need set up of web camara in lenovo laptop to install camera
or
hope this helps
Oct 03, 2012 | ASUS Eee PC 1000HA Notebook
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
When i turn my laptop on i get this message PXE-E61 media test failed what do i do .. i have a lenovo g530
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the laptop, Windows installed and the laptop's device driversplus your programs etc. to get a functioning laptop again.
May 19, 2011 | Lenovo 3000 G530 Notebook
I got black screen a few seconds after reboot my LENOVO 3000 N100, type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and...
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Feb 28, 2010 | Lenovo 3000 N100 Notebook
Drivers for USB keyboard/mouse keep wanting to load after reboot
yes reinstall windows xp and a good antivirus and never update windows again. so take down that automatic updates stuff...
Mar 13, 2008 | Lenovo ThinkPad R60 with Wireless Wide...
Lenovo 3000 C200 Notebook Logo
275 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
