After completing all the steps of installation, I cannot get my new Logitech QuickCam Express's microphone to work. With the Audio Tuning Wizard, I can get to the step called "Adjust Microphone Volume", but then, when I test the volume with my voice, no sound is sent into the microphone, and I get the message called "Microphone Warning" stating that "little or no sound was detected from your microphone" etc. I bought two of these webcams, and neither will work. I'm pretty sure this problem is occuring because when the Audio Tuning Wizard has a box with a dropdown asking for the correct microphone, it only comes up with SoundMAX Digital Audio, which is the audio system in my laptop (and my laptop does not have a built in microphone), not the Logitech QuickCam Express one. So either how can I add a microphone to my audio settings, or how can I get the microphone to work? I have exactly same problem with Quickcam E1000. But 'best solution' below the reported problems simply just logs another problem instead of providing a solution! Help!!
-   I have the same problem... And it is driving me insane!! Does this webcam even have a microphone?
-   Guest
Jan 03, 2009
-   I have the same problem. I can get my microphone on my camera to work fine, but not in Skype. -   Guest
Dec 10, 2008
-   testing the webcam on logitech settings is all good... says everything is ok, but when i try to get sound on skype i cannot hear my voice back.
-   manoeuve
Normal
0
Go to Control Panel and Click on Sounds, Click
on Audio, then Click on the Microphone. Then Click on the drop
down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Comments:
Feb 13, 2009
Normal
0
See section A in the info below to setup the Audio & Video. Also send this to your family
and friends so they have there computer setup properly. Web Camera’s have to be
setup on the program they are to be used with.Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
i have a sony vaio laptop and when i use skpe the connectiond breaks immedialty so i cant use my...
(More)
i have a sony vaio laptop and when i use skpe the connectiond breaks immedialty so i cant use my built in webacm can you pls help?
I attempted to follow your guidance but Im not sure which settings I should use and how to do the...
(More)
I attempted to follow your guidance but Im not sure which settings I should use and how to do the checks
I have a Logitech Webcam Pro 9000 and am using it with Skype but seem to have a problem. It will...
(More)
I have a Logitech Webcam Pro 9000 and am using it with Skype but seem to have a problem. It will start off fine but within a few minutes, the video stream of me freezes. Hope you can help.
