My dimplex plx300n/e somtimes goes off, i then press the reset button on the back and it comes back on , not this time, no power and have tried changing the fuse with no luck , any ideas to what it could be?
judesoul
  • 127 Answers
SOURCE: Dell D610 Power lights come and then go off
check inside the laptop if your processor fan is working properly...sudden shutoff is usually cause when the censor in the board detects that the fan is not triggering to prevent overheating.
going to the nearest PC repair shop would be a good choice.
Posted on Oct 30, 2007
  • 3 Answers
SOURCE: System will not power on!
My system seems to be locked in stand-by. When I unplug and replug the red power light comes on, but bwhren pressed just starts blinking like in stand-by. Help
Posted on Feb 17, 2008
  • 3 Answers
SOURCE: after several reset zen m stuck at no display, completely black but blue led at top is glowing continuosly
Try going to www.creativelabs.com. Click on Support then choose Discussion Forums. They were very helpful when I had problems with my Zen.
Posted on Mar 29, 2008
  • 140 Answers
SOURCE: unit says hello
This problem is normally caused by a dvd player with a dirty lens that it cannot read or detect a dvd in the player. At the same time if this is a dvd/vcr combo a vcr that will not load or is stuck can cause the problem. These can be checked by taking the screws off the unit and taking a look at the position of the dvd laser lens or the vcr position to see if it is in the fully eject position. The part that holds the laser lens to read the dvds can be moved manually back and forth to dislodge it from a stuck position with the power off. Depending on how long it sat around it could just be stuck. You see when you first turn the power on to the unit initially or try to eject a dvd, it will cycle through and try to read a dvd even though there is not one there on power up. If that assembly that moves the lens to read the dvd cannot move, it will cycle off and turn itself off even though you try to reset it with the power button.
A transistor on the power supply can also cause this problem but without taking signal and voltage measurements it would be difficult to pinpoint the exact one. So try moving the laser lens assembly manually and then turn it back on. Let me know. Good luck.
Posted on Jan 15, 2009
SOURCE: Water filter warning light
Push the light - it will flash red after a few seconds -then turn green.
The answer above on this page was correct
Posted on Oct 14, 2009
Is there an internal reset for my privia 330?
to do a factory reset you Turn the Keyboard off the press and HOLD TONE AND FUNCTION and power the keyboard on while holding them buttons. if you did it right you'll see some wierd start up and flashes and then everything will be back to normal. try a few times if at first it doesn't work. somtimes it's picky.
Oct 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Many issues, ie, Everything is flashing!
Hi there
yOU CAN ONLY TRY.
not know if it will work so you go to come back to let us know pleas.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Does anyone know how to solve the "wrong cartridge" error. Is there a reset that can be used? I have tried cleaning the print head without any success.
Hi there not know if it will work so you go to come back to let us know pleas.
button pressing
Feb 14, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
My hp officejet 6210 has a message reading remove and check color cartridge? And I do what it says and it just repeats and repeats?? Whats wrong with it? Should I buy a new color cartridge?
Hi you can try this may work.
In service mode.
Put Stop/reset 4 times orange => reset waste ink.
Put stop/reset 8 times orange => set level ink.
And try this.
For me, it worked when I did this:
1) With the printer powered off but connected to a power source, press and hold the Stop/Reset button for 4-5 seconds.
2) Without letting go of the Stop/Reset button, press and hold the Power button. Then, press the Stop/Reset button two times without letting go of the Power button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Feb 10, 2010 | HP OfficeJet 6210 All-In-One InkJet...
How do you override the ink level gauge on a canon mp630? It has a stop button but no reset button.
In service mode.
And try this.
Feb 09, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Saying it doesnt recognise my ink cartridge but they have not been changed since last printed and were fine before...
Hi
Try this it may work but Please come back let us know how you got on.
and holding
move into a
Stop/Reset button 4 times, the specified number of
alternately in
orange and green, starting with orange.)note: press 4
button pressing
5) Turn off the printer.( it must be turn off)
Feb 06, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Error E42
Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Or try:----------------
TRY THIS STEPS... Reset Counter Service mode operation procedures -
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Aug 30, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Feb 01, 2009 | Dimplex Heating & Cooling
Nokia 3230
hi there dear client, as i read so i think u may have to format ur phone
Dec 31, 2007 | Nokia 3230
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
