Question about Hitachi VM7400A VHS Analog Camcorder
For hitachi VM7400A,what cable gives it power while charging
I wan t to charge my battery while the camera is on. The cable that connects to the camera from the charger is missing when I bought it and I do not know what it looks like and where to buy it.
4 Suggested Answers
SOURCE: Missing DC Power Cord for Hitachi DZ-GX5020A - where to buy?
YOU CAN GO TO PartsStore.com and get one for under $15
Posted on Apr 02, 2009
  • 272 Answers
SOURCE: Have misplaced my battery charger and connection cable.
Cheapest I could find was eBay scroll down you'll see your cam listed.
http://cgi.ebay.com/CHARGER-for-HITACHI-DZ-GX5020A-DVD-Camcorder-DZ-BP07PW_W0QQitemZ220412479950QQcmdZViewItemQQimsxZ20090511?IMSfp=TL090511131005r1436
Posted on Jun 01, 2009
dmjohnson693
SOURCE: cant get my hitachi dz-acs3 ac adapter battery charger to work
the light will not come on when it is plugged in and the batery is set in the charger to charge, even with the dc out power supply the dvd cam will not work, could the charger go bad? does this happen often?
Posted on Jan 01, 2011
Not Charging
Page 18 of the manual says: Only use cable and AC power adapter, delivered with your camera to charge the battery. If you use another adapter, or cable the camera battery could not charge or not work properly.
The manual, does not indicate you should be able, or you could charge the battery, when you connect it to a computer. And although on the outside a cable can look the same, it would be better you use the original cable, that came with the camera. Make sure you switch off the camera before charging and check if all contacts in the camera and on the cable are clean and not bent.
Mar 22, 2014 | Samsung ST66 Digital Camera
I have a GC-XA2BU and the camera will not cut on? I have purchased a replacement battery but neither work.
As soon as you connect a camera to a computer, it will stop working, because the USB connection will be used to charge the battery.
If your computer is not correct wired on the USB port, or when you are using a hub, without an external power supply, the battery will not be charged. So you end up with an empty battery and a camera that does not respond.
Try charging the battery on an external charger and remove the USB cable, before switching on the camera. Also check if the USB connector on the camera is free. Avoiding the camera to "think" there is still a USB cable connected.
Feb 11, 2014 | Cameras
Hi I have the vivitar vivicam 8025 dont have my manual want to know how to charge my battery
First off, you can download a PDF version of the manual from the manufacturer at: http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
If you don't have a PDF viewer, you can download one from: http://www.foxitsoftware.com/pdf/reader/ (just click download under the free version)
For your convenience I've pasted the relevant information about charging the batteries from the above manual:
Please charge the battery as below 2 methods: A. Charge with USB cable Insert the lithium battery into your camera correctly, and connect your camera to computer with USB cable. The red LED of camera will be light on indicating that your camera is in charging status, the LED willbe off when charge full.
B. Charge with supplied charger Your camera is supplied a compatible charger for you, you are only required to put the battery into charger and charge the lithium battery directly from electrical outlet
Please leave feedback if this was helpful. Thanks.
Apr 11, 2011 | Vivitar Cameras
It will not charge
I have the exact camera, when you plug it in does the USB cable show red? If so this means the cable and the battery are connected and the red is a charging status. If you can turn on the camera while it's plugged in then its not the cord or the camera but the battery. If it just fails to charge but does power up and connect via USB i would look into a new bettery. If the USB cable does NOT respond at all when plugged into the PC by itself then the cable is bad and you need a new one. It will flash red/green/yellow if it's 100% functional. If your cable does respond but does nothing when the camera is plugged in then it may also be the cable's connections or the camera's internal port has been damaged. If you want to make sure it is the battery then plug in your cable, wait for it to cycle through the colors and connect your camera WITHOUT the battery inserted. It should do nothing, then while its connected to the cable insert the battery, If the cable turns red but will not charge then it's 95% a battery issue.
Jun 28, 2010 | Samsung SL420 Digital Camera
Can you trickle charge the Olympus FE-20 via the usb cable?
Very few cameras will charge through USB ports. This is only to connect to computer to access pictures. Your camera will not charge via USB. I suggest to many people that using cameras that take AA batteries is the best cameras to buy when traveling. Many camera owner fall victim to different voltage outlets when travelling.
Jul 02, 2009 | Olympus FE-20 Digital Camera
I cant upload my videos from my SDR-H40 HDD camera onto my pc
hey bro u know all the cables n the battery charger? u take them ntake the battery outta the camera, put it on the charge, put the battery that connects by cable to the charge in the camera, then plug it all in. should work for ya
Jun 22, 2009 | Panasonic SDR-H40 HDD Camcorder
Digital Camera batteries don't last
yes it is possible to leakages the batteries but ur probleum is doen't charg the battery.Plz it discharg battery fully and then charg it again i hope ur probleum is solved.
Jun 09, 2008 | Cameras
Looking for owner manual
Go to
this page on devicemanuals.com
and pick the manual for your Hitachi product from the list.
Good Luck
Dec 25, 2007 | Hitachi VM7400A VHS Analog Camcorder
I can't charge the battary.
Disconnect DC power cable from AC adapter/charger. Battery charging will not be possible if the DC power cable is left connected to the AC adapter/charger.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Hitachi VM7400A VHS Analog Camcorder Logo
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
