I have an intel p4 system.the problom is continuesly restart  i change my smps.with new the same problom. what is the problem?
    Scholar:
  • 81 Answers
welcome to Fixya,
think the is that your PC system cannot detect your hard disk.
try to determine if your hard disk is detected. in booting process please press F2 or Delete tab. in the booting process see your hdd is detected.
if not, check the power supply and IDE connector if it is connected properly. and you can also check the hdd in holding by bare hand ontop. not in the lower case with electronic parts. if it is running. with no sound of mechanical problem. check the IDE or SATA cable. try to fix it that really fit to every slots.
if your hdd is detected then, you have too many start up programs. you can restore it, by pressing F8 during boot process.
restart to the last known or safe mode and
run on safe mode, make opening of documents and etc..
Posted on Dec 08, 2008
    Genius:
  • 1,226 Answers
maybe you are infected with virus causing your system to restart. sometime this also causes by hardware conflict. if you can boot in safemode then you can fix this by uninstalling the unwanted softwares and hardware. but most of all if you are not infected with virus to repair the installation of your windows. but if you are infected still you need to back up important files and then format and reinstall the windows..you can find notes on installing window by going to google and then find " installing windows"
may this help,
before you do that, try in first boot press F8 to select boot menu and try booting your computer at last known good configuration. hope this success. if not back to above solution.
melnavz
    President:
  • 2,110 Answers
Try to change the RAM..
My desktop PC with Intel DH61WW mother board, Intel i 3 processor, 4 GB DDR3 RAM, Windows 7 OS Intel HD Graphic S/W has auto restart problem while shutdown is attempted. The UPS power is to be switched...
Disconnect all peripherals, except keyboard, mouse and monitor. Try to start the machine in safe mode and if it comes up okay, then try to restart it into normal windows. If the problem continues, remove all but one stick of ram, and try again. if it happens again, change out the stick of ram with one of the other ones. IF this fails, and the problem still exists, try to boot from a usb drive. If it boots normally then you may have a problem in windows, and that may need a re-install.
Sep 29, 2013 | Computers & Internet
Hi , my name is Nitin and the problem i am facing with my PC is that it gets restarted after every 10 to 15 minutes while playing games and it starts disk checking everytime it restarts. This happens even...
The following tip is not for the same model, but for the same kind of symptoms :
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/183116-asus-p5p800-p4-3-0ghz-random-reboots.html
Dec 18, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
I have purchased intel dot station from big apple near hdfc bank secunderabad paradise 2 year s ago it is not startinig if startininig also power button ble light is glowinig and after 5 minites top green...
You cant change the SMPS of this computer as it is built on big PCB and not a regular SMPS box. Then it has a supply for monitor too. And it is not required.
Clean your RAM & reinsert it and re-install Win XP after low formating the drive. It will definately work
And 'Intele', this is a useless, non upgradable & and non-repairable system and to upgrade it with PIII 700MHz CPU you got to add a small resistance to it which onl6y the dealer can do it for you.
Now a days there are lots of used branded P4 systems available in the market - 'dirt cheap'. Dell Optiplex GX280 is one of the good option with P4 3.20GHz pinless (LGA775) CPU, 2GB DDR2 RAM, 160GB SATA drive with Dell usb Keyboard & mouse. Prevailing market price is app. Rs. 7000/- Add Rs. 2000/- for 17" used multimedia monitor.
You can compare all this with Intel Dot Station.
To reach the motherboard of Intel Dot Station one has to unscrew 32 screws. Its so complicated. Spares are not available - then why buy P-III these days?If you are in New Delhi, go & buy from Nehru Place.
Jan 15, 2010 | Intel Dot Station (INTC300AIO) PC Desktop
I want to buy SMPS for D865GBF motherboard , P4 Hyper Threading processor.Which brand i should go for?
SMPS is not based on the motherboard , you can get any branded SMPS it will suit your motherboard.
Nov 06, 2009 | Intel D865GBF Motherboard
Problem with pc
You probably need to check the cooling fan setup ( some motherboards give the control on the task manager or a sperate software to control it) This seems to be a problem of overheating which might have started after the installation of new ram.
Feb 28, 2009 | Intel Computers & Internet
Asus p4gb-vm main board problem
Hi shameer123,
The above scenario confirms board failure. This is due to wear and tear which we cannot prevent.
I believe it is time to replace with other P4 478 chipset board available in your country.
Jan 01, 2009 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
My system is restarting
u just open the system in safe mode one time and scan syatem through an antiviruse.........if it helps then it ok and if not then u have to format ur pc
Dec 11, 2008 | Intel Biostar IDEQ200S P4 Barebone System...
Problem with installing video/audio drivers..
i don't have audio driver of intel p4 processor.how can i download it?any website for that?
Dec 03, 2007 | Intel 845GE Motherboard
Intel Original Motherboard 946 with duel core processor.
As you said the system is restarting because of power section problem.
Try to change SMPS and see the difference. Even though if it fail.
Try using single ram if problem repeat change with other ram.
Else
Load bios defaults.
If Not Ok
Contact Intel Support:
With your bill No, Serial No & model no.
or you can mail to: apacsupport@mailbox.intel.com
Hope this will work...
Bye..
Nov 21, 2007 | Intel Motherboard
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
