Question about JVC KD-LX50 CD Player
Making a wiring harness for JVC headunit Model KD-LX50
L have acquired this headunit but unfortunetly it did not come with the wiring harness for installation.So l am open for advise on how l can go about making my own and or where to source the relivant detailed wiring diagram breakdown.There is a small diagram on the unit itself but l am still not 100% on the exzact layout.So if anybody could help me out that would be great thankyou.
  • Anonymous Mar 15, 2009
    Hi i need a wiring diagram as well
    I have the same problem if anyone has a wiring diagram
JMuskovitz
  • 135 Answers
SOURCE: JVC KD-S640 pinout needed
For ten bucks, you can buy a new connector: http://www.jvcservice.com/store/ProductDetail.asp?part=JV16-0001A To figure out how to wire it: http://books.jvcservice.com/download/256614688/28879.pdf Page 25 describes the color of the wiring in the harness.
Posted on Mar 29, 2007
SOURCE: help with installation for car audio jvc model no. kd s585
HOW TO HOOK UP A JVC CAR CD PLAYER TO A 1993 COUGAR
Posted on Mar 08, 2008
SOURCE: JVC Wire Harness
i need to match up color wire to my 1998 honda accord
Posted on Oct 22, 2008
josetejas
  • 300 Answers
SOURCE: Just installed jvc kd-s16 and it loses power after
Connect Yellow to Battery (always 12V), red to ignition, and black to ground. Disconnect all others. Check it. If the radio stays on and plays CD, then radio is good. You may check other wiring
Posted on Jan 19, 2010
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
My jvc stereo will not power up but have found the black wire is live ?
hi peter, before you start using the rest of the harness cables find out if the harness you have is a jvc original for your model. the black wire is the ground/chassis cable only for a jvc kd-r411. you mite be using a compatible fitting harness whose " wire colour configuration" is incorrect for your model. cheers.
Mar 02, 2013 | JVC AM FM CD DET FACE CAR STEREO
Where can i find new wire harness?
You can obtain a new wire harness from pacparts.com. The part number is JV16-0003. You can also call them at 1-800-421-5080.
Feb 28, 2012 | JVC KD-LH3150 CD Player
JVC headunit oranges with white stripe (illumination wire).
As far as I know, If the illumination wire is connected, the radio dims the display when headlight is turned on.
Feb 20, 2012 | JVC Car Audio & Video
JVC KD-R616 Car Audio Receiver wiring the speakers without the amp
The Front left and right speaker lines as well as the rear left and right speakers are marked on the output wires of the car stereo. These are marked and the positive line will be usually the wire with the same colour but with a line.
You can connect these individually to the speakers one by one... use the car harness if available.
Feb 04, 2011 | JVC Car Audio & Video
Need to find a wire harness to in my radio does not have to on that goes from radio to car harness. where can i find on for a JVC model KD-LH1100
Car harness adapters can be purchased in Best Buy or Crutchfield just give them the make & year of your car. Try Metra and call to see if they still make Universal harnesses for JVC so you can connect it to a universal harness to your type of car. Just click them together to avoid soldering or taping with electrical tape.
I use to work for Circuit City Roadshop and they(METRA) only made it Exclusively for Circuit City and nobody else in 2008.
Apr 09, 2010 | JVC KD-LH1100 CD Player
I NEED A WIRING GIAGRAM BECAUSE THEIRE IS NO COLOR TO COLOR PATTERN ON BACK OF MY JVC-KD-G320
This may help your cause
http://www.nodevice.com/manual/JVC/page24.html
Jun 11, 2009 | JVC KD-G320 CD Player
Remote wire?
The remote wire on the jvc unit is blue/white stripe if that isn't there it's the blue wire
Apr 08, 2009 | JVC KW-AVX800 CD Player
How do I get sattelite radio on my jvc? How does it connect?
I'm not familier with this specific player, but my guess is that it doesn't have a built in satellite radio receiver. It probably controls and displays an add-on satellite receiver that is hooked up to it via a special wiring harness. It's pretty much the same thing as how some headunits can control and display an Ipod...
Mar 20, 2008 | JVC KD-G720 CD Player
JVC KD-LX50 CD Player Logo
280 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
