Question about iRiver PMP-120 Digital Media Player
Asking if thier is iriver usb charger for my T7 mp3?
Because i'm always put in the computer.im tired of doing this thing
  • 903 Answers
What are the tyre pressure of a ford focus 1.6 automatic 2014
Coming from someone who has worked for Chevy,Ford,and Chrysler dealerships we had to gauge the tires by what the sticker said on the door jam at the driver side..I disagree with it...It is always best to gauge tires with the outside temp because cold weather and hot weather make a huge difference...NASCAR racing can drop a tire pressure on one tire and raise it on another for better traction on the constant left hand turns...Just a 1/2 of a pound can make a huge difference..Tires tend to swell in hot weather and on long trips..another reason it normally says to gauge a tire while it is cold which means been sitting still overnight..It doesn't mean cold weather...However tires won't swell in cold weather...I like running 40 psi in tires if it says 32 or 35....this will give you a good flat even tire wear...I have always added 5 pound to whatever it told me to gauge it at...If a tire wears out on both edges it indicates low air ..,also tire alignment can wear one side of the tire....If it wears in the center it means too much air...It is hard to keep them perfect because of rotations..,weather ,and certain terrain but it can be done by checking them every month....Some tires have different pressures written on them that is different than the door sticker...To answer your question ...Add 5 pounds to the door sticker...,your tires will last longer..They won't last as long with door sticker pressures which will give dealers more tire business...Another thing dealers do is put nitrous in tires instead of air which is supposed to keep air from swelling and changing in the summer and winter...This is good..It isn't Nitro that explodes.....Always tell them to gauge them with your choice of tire pressure....
Feb 22, 2015 | Ford Cars & Trucks
How To Repair Ford Taurus
if the steering wheel is vibrating it may only be tire balancing ,, but whoever put on the tires should have done this ,,, if you jack up te car in front ( and do use axle stands ) catch the wheel top and bottom there should be very little play in it when you rock it ,,, try the same across the wheel ie quarter to 3 ''' if you find excessive play a bearing or steering linkage part is worn ,,,alignment wont cause vibration only uneven tire wear ,,,,,check the play asap because if a balljoint of steering part is badly worn this could become dangerous
Nov 22, 2013 | 2004 Ford Taurus
My back tire wont allign correct. im sure it has to do with the washer im not sure where to put. any answers?
there is a coller on either side of the wheel, they will really only fit in their correct side, as they locate in the seals before the wheel goes in the swing arm, there is a thin washer with the nut, checy the adjusting blocks are the right way, with the adjusting bolt heads touching the edge with the step
Apr 11, 2010 | 2004 Yamaha YZ 450 F
Replacing Chevy Trailblazer Spare tire mount/hoist.
Check out item 330335042615 on Ebay...
it''s the whole jack, handle etc... 50 bucks!
Tah dah!
Jun 09, 2009 | 2002 Chevrolet TrailBlazer
Different tire sizes...
I've always heard that it is ok to put different size tires on the front and back as long as the vehichle is not AWD.  The two different size tires turn at different rates and can cause problems for you.  I would probably change the other two.
May 17, 2009 | 1991 Nissan 300ZX
I have a Dell Inspiron B130. I have brought 3 chargers. The computers has to always be pushed in or wiggled around to actually be charging. I think that it is the input prong. It seems to be loose and have...
The problem is not the chargers, it is the power connector on the laptop. Yes it can be fixed, laptop need to be dismantled to get access to this connector and a new one to be soldered in.
If you can't do it yourself the cost of fixing it may be expensive and if the laptop is a fews years old, it might be better putting this money towards a new laptop.
Nov 30, 2008 | Dell Inspiron B130 Notebook
2005 ford focus, is there a special location that they put the lug nut key?
The lug wrench is
located in a bag next to the spare
tire (3–door and 5–door models) or
on top of the spare tire (sedan and
wagon models). and the key was in this bag.
but they dont always get put back.
im sure you have checked your glove box
if you cant find it any tire repair shop can remove the lock and replace it with a standard one.
good luck
paul
Nov 26, 2008 | 2005 Ford Focus
Humming
only things ive can across with type of prob and u did one with hub some brakerotors were bad causing noise on these cars only other things is a bad wheel/tire balance, alignment also some cheap tires are extremely noisy ive always had good luck with bfgoodrich tires
Jun 18, 2008 | 2000 Oldsmobile Alero
Computer language
change your languge settings from control panel..regional and language settings...
Mar 18, 2008 | Computers & Internet
iRiver PMP-120 Digital Media Player Logo
76 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
