Question about ViewSonic Televison & Video
Remote doesn't work. new batteries installed.remote doesn't lite up when any buttons are pressed
  • 417 Answers
Double check that you have the batteries the right way round as the remote is polarity sensitive also make sure the batteries terminals are making proper contact. Then try again.
Please remember to rate this solution.
Posted on Dec 08, 2008
The eye for the remote control is not lite up, why?
You mean the Red part at the end of the remote? That is where the signal comes from but it is infrared so invisible to the naked eye. You should have a small LED on top that lights up red when you press buttons. If that is not working, you need new batteries or a new remote.
May 22, 2016 | Televison & Video
REMOTE NOT WORKING
Please remove the remote control's batteries, then press every button twice. Then install new batteries and press the [TV] button, then press the [POWER] button.
Mar 23, 2014 | Panasonic PT-56LCX16
Volume and mute buttons are not working
Do you have fresh batteries in the remote? You did not provide your TV brand so I can't provide you the codes for your specific TV. Below I have provided instructions on how to perform a power scan. If this doesn't work, you may need a new remote.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the redTV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 17, 2011 | DISH Network IR Remote Control
Remote will not respond to any of the satellite commands...
Have you replaced the batteries? If you have, which mode button lights up when you press Select on the remote? I have provided instructions on how to readdress the remote to your receiver. If this doesn't work, you may need a new remote.
  • Remote: All Other Remotes
    1. Go to System Info screen.
    2. Hold down the SAT button until all mode lights at the top of the remote light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button.
    5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Aug 12, 2011 | DISH Network 135899 Remote Control
Remote doesn't work even with new batteries
make sure the remote batteries are in the correct + and - way. It could also be that the remote is broken. If nothing comes on when you press the power button and the tv doesn't respond, then the remote is broken and you should buy another one.
May 28, 2011 | GPX Televison & Video
Remote does not work unless I am in the garage. Outside the door it will not work.
hello emar... check to be sure that the little wire antenna is hanging down from the back of the garage door opener motor. Then check it. If it still won't work from outside, install new batteries.
If that doesn't do it, remove the new batteries and use the eraser end of a common pencil to clean the battery contacts inside the remote. then reinstall the new batteries and try it again.
May 04, 2011 | liftmaster 83lm Billion Code 3-button...
I need instructions for the zenith universal remote 3201 for a new Panasonic LCD TV
If you have a manual for remote and you try all codes for your model and it didn't work, you may try for automatic search. First turn on TV, and point the remote toward the TV. You press: SETUP and hold, and press button for device: TV, lite is on, then you release all button and press again SETUP, just once, the lite is blinking, now press the power button on a few seconds. When your tv is turned off, you press button TV. Press button for power and it will turn on your tv. Try other commands on your remote, if everything is working that's it, if not do procedure again. Hope this was helpful, if not, ask more. By!!!
Nov 03, 2009 | Zenith ZN-501S Remote Control
I need to program my new dishnet work remote
Turn the receiver off using the front panel power button and then press the channel up button and hold it until the unit powers on. This will bring you to the system info screen. There you will see the remote address the remote needs to be programmed to- usually 1. Now press and hold the SAT button on top of the remote until all buttons on the top lite up and release. Now key in the two digit number shown on the screen - numbers under ten will be preceeded buy a zero. Now press the pound sign on the bottom right of the keypad. The SAT button will flash three times and then you will need to press the record button . YOU SHOULD BE ABLE TO MANUEVER THE HIGHLIGHT ON THE SCREEN AND EXIT OUT OF THE SCREENS . Thanks for using Fix Ya. ---and if you can not bring up the system info screen perform the steps on the remote itself until you reach the correct number that will control the receiver- 01 thru 16. if you need further assistance please let me know.
Mar 28, 2009 | DISH Network 301 DTV Receiver
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
49 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
