TV wont stay on
I went away for 4 weeks and unplugged the TV and aerial. On my return I plugged everything in, the red light came on but when I press the on button on the remote it fades as if the TV is going to work, then clicks and the red light comes on again.
Is there a reset button somewhere on the set????
  • coralhorton Dec 08, 2008
    Dont know what pcb is or how to check horizontal output.
  • 105 Answers
No reset button on the tv maybe the tv is shock when you switch on the tv cause sometimes lizard always stuck down the pcb...try check the horizontal output
Posted on Dec 08, 2008
My technika lcd40-920 tv wont turn on standby flashing blue to red i held power in 30secs n stopped flashing but still wont turn on why some one said its trying to update but not sure can u help
How long have you had this TV? If it is under 12 months, get it fixed under the guarantee. If you have an extended warranty, use that to get it fixed.
I would suggest that you switch everything off, remove all the cable from your satellite box or games console and everything else, then switch off at the mains and unplug the set.
Now press and hold the power button on the TV for 30 seconds.
Now plug the TV into the mains again and use the TV button to switch on the set. If the lights continue to flash, then it's a repair job. If the lights are steady but there's no picture, then switch it off using the TV button and reconnect the aerial cable first and try it again.
Once you get a picture displayed, you can begin to reinstall all of the other cables until everything is working again.
Apr 13, 2015 | Televison & Video
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
Only the red light comes on
Whats up Wade?
This is DVD MIKE with Perfectimagess.Try this first .Unplug the TV for a while and press the On/Off button which is supposed to perform a "reset".After that, plug the TV back in. It should come on and the Timer light off. The picture and colors might be distorted, but pressing the Perfect Focus button on the remote control resolves this right away.
The problems is a black picture or the TV won't turn on. The Timer light stays lit even though no Timer has ever been set. The colors converge and the picture is pinched. I don't think all of the expensive repairs are necessary, My TV did go out after a week of non-use while out of town (I was out of town, not the TV). I don't know. I'll post more if I learn more. I hope this helps Wade,
Vacuum the dust off of the circuit boards and inside the cavity. TAKE CLOSE UP PICTURES OF THE CONNECTORS BEFORE DISCONNECTING FROM THE CIRCUIT BOARDS. (IF YOU HAVE TO.) TAKE OUT CIRCUIT BOARD MOUNTING SCREWS. AND REMOVE THE BOARDS.
VACUUM THE DUST. LOOK- SMELL AND CLEAN THE GROUNDS, AND CAREFULLY CLEAN THE BOARDS. ASSEMBLE. DOUBLE CHECK CONNECTIONS WITH PHOTOS,
AND PLUG IN, TURN ON AND HOPEFULLY ITS ALL GOOD.
WADE WORK WITH ONE HAND AS MUCH AS POSSIBLE SON!!
DVD MIKE
May 14, 2009 | Akai PT4298HD Rear Projection Television
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Jan 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
TV won't turn on
When I try to turn the tv on, the green light flashes and eventually goes back to red. A very faint picture came across the tv a few times but didn't stay. The tv is only 3.5 years old.
Jul 10, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Electro Med Services...
