Question about GE Profile Harmony DPGT750EC Electric Dryer
Access to blower
Problem: Sometimes the dryer heats, sometimes it doesn't. The GE repairman came by today and hooked up his computer to the dryer. Without opening the machine, he told us that the blower was not working... and for $700, he could fix it. Because it works sometimes, and doesn't work at other times, I'm hoping it is a loose wire or something. Even if I have to replace it, I can get the parts for less than $200. However, I cannot find a way to access the blower without taking the whole machine apart (ie. top panel, then side panels and drum). Anyone know how to get to the blower in a relatively easy way?
  • Steven Ohliger Mar 21, 2007
    Okay - here is the scoop. I did manage to do it myself and it worked!!!! Yes, it was complicated - mostly keeping track of the screws and where they went (after I removed a piece, I put the screw back in the hole). I had to remove the top panel, followed by the front panel. Then, the duct work had to be removed. I finally had access to the blower. I think the hardest thing was loosening the bolt that held the fan to the motor. Replaced the motor. Put it all back together (with only a few back-tracks) - and it worked. Praise God!
  • jecx Nov 22, 2007
    Same problem here..sometimes blower goes on..sometimes not.Anything to check before calling a tech guy?
  • 67 Answers
No on the harmony there is no easy way to take it apart. And pretty much no repair is easy on it especially the blower sorry for the bad news its a pretty advanced repair.
Posted on Mar 21, 2007
I have a GE DCVH660GH0BB gas dryer.That doesn't heat or sometimes heats for a short while then stops heating.
You will need to check the thermostats on the blower housing for continuity.
Nov 23, 2012 | Dryers
I Have a GE monogram 1989 refrig. Model BISB42EKB
The defrost thermostat is located at the left rear side of the evaporator coils. Sometimes you will have to deinstall the fan blower to access it and sometimes you can get your hands around the fan. Watch out for the plastic clips because if they are cold, they will be brittle. You can access through the front, after removing the fan and the shields surround it. Try the shields first, and then see if your hands are small enough to fit around the fan motor. Just warm the clips with a hair dryer so you don't have to replace.
Dec 02, 2011 | GE Refrigerators
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
Hooked up ge dryer 463eg6ww serial number sr746394a The electricity works but no heat? Used a voltage meter and the voltage is correct
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | GE Dryers
Dryer will not start
You can access the front thermal fuse if you remove the four screws holding the front panel on.((two in door and two opposite) Pull out on front top of panel, and pull off hooks on bottom after getting pulled out on top. sometimes door can stay on on its hooks, but need to take out four screws. There is a white one inch long fuse by blower that may have opened, another on heat cone which is less likely. Clean venting if this is the problem. Have unplugged, and watch out for sharp edges.....
good luck
Mar 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
GE Profile Dryer. Sometimes fails to heat or just air dries.
Cold solder joints on blower motor coils. Needs re-soldered. I suggest finding a buddy who knows how to take the dryer apart and knows how to solder. Luckily for me, I know how to do all of that, I had the same problem you have.
Oct 19, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge harmony dryer not heating up dpgt750ec1pl
If you hear the blower ramp up when you start the dryer and if slowly ramps down or quits all together then you need to replace the blower. If the dryer heats at all then look at the blower.
Jun 20, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
190 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
