Enter bios setup on A6000 notebook
I would like to install now OS on my A6000 notebook. I need to change to boot sequence. To do this I need to enter into bios setup, but I don't know which key to hold during the power up so that the notebook enters the bios setup.
    President:
  • 2,110 Answers
U have to press F2 Or Del key...
Posted on Dec 08, 2008
  • 903 Answers
Press the F2 button.
I'm trying to help a friend install
After "Fast Boot" has been enabled, you cannot access the BIOS setup during power on . The machine will bypass "Press F2 to access Setup Utiltiy and F12 for Boot Menu" prompt.
This is a bigger issue if the hard drive crashes and access to Windows is not possible OR
Fast Boot can be enabled or disabled in the BIOS setup, or in HW Setup under Windows.
If you have Fast Boot enabled and you want to get into the BIOS setup. Hold down the F2 key, then power on. That will get you into the BIOS setup Utility.
You can disable the Fast Boot Option here. You will need to disable Fast Boot if you want to use the F12 / Boot menu.
Aug 26, 2011 | Toshiba Computers & Internet
I need password to enter bios setup to change boot sequence so I can boot from usb to install new operating system
You don't need to access bios to change boot drive just hit escape key a couple of times when you power on and it will give you options for which drive to boot from.
good day
Nov 03, 2010 | ASUS Eee 4G Notebook
When I turn on my computer, it goes to a black screen and says, "Disk Boot Failure, Insert Disk and Press Enter". I am also seeing an Error Code BIOHD-2 and it say Warning no drive detected. Can you help...
Possible tha the PC is infected and has the booting sequence faulty , some files are lost. you must reinstall the OS , format teh drive , then install an antivirus and finally the PC harware drivers.
Sep 19, 2010 | Computers & Internet
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
How to Install WinXp in Vista Platform
There is very simple procedure.
  • 1st restart your Laptop and enter in bios setup with the help of F2 key or F1 or Del key.
  • After entering in BIOS setup change the Boot order or Boot sequence.
  • Select the booting device 1st boot from CD Rom.
  • Save the setting.
  • Insert windows XP Cd in CD Rom.
  • Now Computer start from CD Rom.
  • You follow the instruction and install the windows.
  • Compaq Notebook Drivers
Mar 20, 2010 | Compaq Presario Notebook
Can't get the windows screen to come up on the computer only a blank screen with the cursor blinking in the top right hand corner. acer aspire one notebook
Change the boot sequence in the bios and let the windows be in the top drive, save changes and exit let it boot from the disk and follow the steps below
Do a repair of your XP installation.
•Boot from the XP CD
•At the Setup screen - Press enter (NOT R for repair)
•PgDn and press F8 for the Licensing screen
•Select the XP installed location and press R to repair
•Setup will copy install files and then reboot the machine DON'T REBOOT FROM THE CD. Let it boot from the hard drive.
•When it is done the process, remove the CD and reboot normally.
This applies to all os like win xp vista and win7
Feb 02, 2010 | Acer Aspire One PC Notebook
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
How to change boot for cd or hd
That is done in the bios.
you could also watch the boot sequencs and see if it says somthing along the lines "press F10 to change boot order"if so that is another option
If this info was useful please click
Aug 13, 2009 | Toshiba Satellite 2400-S251 Notebook
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Nov 15, 2007 | Compaq Presario M2000 Notebook
Boot from CD
hi...i had a problem that my friend bios password and he forget now...now system is got crashed..i want install new os..but for that i have enter to bios settings...anybody tell wat's the default password ...mine is acer travelmate 5720.....i need a password now...pls anybody help..
Jun 21, 2007 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
