Question about Whirlpool LHW0050PQ Front Load Washer
Washer fills with washer
Hi my washer fills with water, but thats it, i can move the inside both ways quite easily, so i know its not the pulley, or belt, and the motor is good, i'm thinking its just the reset button, which i cant seem to find on this partiular washer machine....single mom of six, cant go more then a hour without a working washer machine..the inside sais stylemaster 90765....thanks
    Scholar:
  • 135 Answers
Hey there,
The problem is either electronic (NOT GOOD) or the sensors that wheigh the drum...
either way you are more than likely going to have to either get someone to service at and check what is faulty and replace it.
I do apologise if im presuming a single mopther of 6 will not be stripping a washmachine, locating the central circuitry and weight sensors, testing them, determing if they are faulty, then sourcing a suppliers, purchasing the parts then reinstalling them and then finally reassembling the washing machine...
if you can do the above then i take my hat off to you...
good luck !
Posted on Dec 08, 2008
I have a whirlpool ultimate care ii heavy duty super capacity plus washer that fills, and agitates, but will not "spin" or drain water. What do you guys think needs replaced?
"If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it."
May 04, 2015 | Whirlpool Washing Machines
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Water will not drain. sewer line is not pluged. Customer service says I could have a plugged filter at the pump ( we have dogs). How do I get to the pump to unclog it. Model EIFLS55IIW woody
Hi agnes! Washing machines, including those built by Frigidaire, have internal pumps. These pumps help drain out the water from the washer tub between the wash, rinse, and spin cycles. If the pump is damaged or the pump pulley system is frozen/stiff, the water can become trapped in the washer tub. In both cases, the pump assembly needs to be replaced. You can check by looking for a few signs that a pump is dying or already dead.
1 Start the washer and wait for the washer tub to fill with water. If you do not hear water or hear a motor whirring, the washer motor may be dead.
2 Open the washer lid in mid-cycle. Note whether or not the inner tub is still spinning around. The inner tub is the inside surface of the washing compartment with many holes for water draining. If the tub is not spinning but the motor is running, it is possible the pump is dead. Check the pump pulley by removing the pump from the washer and trying to rotate it by hand. If the pulley doesn't turn freely and is frozen or stiff, replace it. Also, if the agitator is moving but the tub isn't, this is a sign the pump is dying. For front-loading washers, do not attempt to open the door mid-cycle. Look through the glass door. If there is enough water to come up against the door, the pump is malfunctioning.
3 Wait for the washer to finish its cycle. Open the unit. If water is still in the tub, the pump is likely dying or dead.
Sep 04, 2013 | Electrolux EIFLW55I Washer
I have a Maytag Performa Washer...It will fill with water but will not move through the cycles...it simply sits full of water and you can hear a humming noise and a smell possibly like rubber. A friend...
sounds like either you have a stuck pulley or pump remove water with shop vac and tilt washer against wall get under washer remove belt spin small pulley by hand does the pump pulley move all directions freely if not something stuck in pump or is belt melted or worn out
Jan 27, 2011 | Washing Machines
My washer starts, fills the water, then stops,
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 05, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Our front loader fills with water, begins to spin a few times and then stops. Water remains inside, not draining and all the clothes are soaked. The washer lights all begin blinking and it won't move into...
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line...
Sep 23, 2009 | Kenmore 44102 Front Load Washer
Hi. My water level knob is very hard to turn and the water level is not correct when filling the washer. Any thoughts?
if it has been quite some time since you turned the knob it is possible that it is starting to sieze up, you may have to replace the switch behind the knob
May 09, 2009 | Whirlpool WTW5560SQ Top Load Washer
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mar 03, 2009 | Washing Machines
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Washing machine
I'll start with the least expensive problems and work my way up to be somewhat encouraging!
* If the machine fills with water AND it doesn't spin OR pump the water out [and you cannot hear the motor running] the lid switch that triggers the machine may be defective or broken. For safety, washing machines are made so that they cannot spin with the lid open. The lid switch "tells" the washer that the lid is closed, so if it breaks, the washing machine may be able (in some models) to fill but not spin -- in some models, it may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. Not sure if this is "kosher"or not, but I have checked this myself without taking anything apart by carefully inserting the tip of my finger into the small hole where the lid closes. When I did push the little pad just beneath the surface of the hole, my machine started working. . . when I moved my finger, it quit, so I knew it was the lid trigger switch that I needed to replace.
* If your machine fills up but won't spin and won't pump water out [but you hear the motor running] it could be the pump pulley that has become "frozen" or stuck. To check this, remove the pump from the washer and try to rotate the pulley by hand. If it won't turn fairly freely -- it it's really stiff or won't move at all, or, if the pump belt is broken -- replace it. Many machines have two belts -- if either is broken, it could result in a problem like the one you've mentioned.
* If the washer pumps water out but won't spin, the motor coupler may be broken. Many machines are made by Whirlpool [Kenmore, Roper, etc. are all made by Whirlpool]. These washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. These can wear out with time, and this may be a problem if your machine is an older unit.
* If the washer pumps water out but will not spin or agitate (or, if the water will pump out but the machine will either spin OR agitate but not both), the drive motor may be defective, either totally burned out or only burned out one one of the two sides/directions [the spin/drain is one direction of the reversing motor, the agitation is the opposite direction]. If one of these cycles works and the other doesn't, possibly the drive motor has burned out in one direction only. If this happens, you need to replace the entire motor.
* If you hear a really loud noise when the machine should be spinning, it could be that the spin bearing or basket drive may be worn or seized. These components let the inner tub spin freely inside the outer tub. This would be a repair for a qualified technician.
Jan 11, 2008 | Kenmore 63942 Dryer
Whirlpool LHW0050PQ Front Load Washer Logo
83 people viewed this question
Dan Webster
Dan Webster
Sal De
