Question about Samsung Washing Machines
Error code SE on a Q1233 samsung washing m/c.
  • leturtle Dec 08, 2008
    Yes....just got back from trip and took my wife's version of error code. But it is a '5' and the 'E' is flashing.
    Genius:
  • 1,239 Answers
HI AND welcome to fixya
can you tell me which is the error code coming
Posted on Dec 08, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 08, 2008
    if it is ue error
    For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
    For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
  • ABHISHEK.C
    Error code 5d is for over suds.E20 error code that will not allow my washing machine to finish the spin cycle.1. Check the drain hose and make sure it is not plugged or kinked.
    2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
    3. Check/Clean Drain Pump Filter of foreign objects
    4. Check for Drain Pump Failure.
    5. Check the Inlet Valve for proper shut off
    6. Check the Pressure switch for proper operation.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, could the error code is a "5E" not SE. In any case, pls clean completely the drain system from the filter, to the collector, impeller, pump/valve including the drain hose (check for kinks, collapsed).
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
I have a samsung front loader that has error code of SE on the screen and is not completing a full cycle.. what could that be
Hello!
"SE" error basically means:
High/Low voltage detected.
How to resolve:
Restart the cycle.
If the code reappears, call for service
I also add a link to the manual to a Samsung washing machine. Hopefully, it will help :)
http://manualsbrain.com/en/manuals/1797935/?page=33
Jul 17, 2017 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Samsung Dishwasher model DW80F800UWS with Error code 5E or "SE" error code.
    The 5E error code on this Samsung dishwasher means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor. If this is Greek to you, then you should probably call a professional dishwasher repairman.
    Jan 10, 2015 | Samsung Dishwashers
    Oven shows -se- error,and now doesnt heat
    Sorry but the -se- error code from the manual means:
    An error of the oven may cause
    low performance and problems
    in safety. Stop using the oven
    immediately.
    Call local SAMSUNG service
    centre.
    Look for the 1-800 number on the back and give them a call.
    Jun 10, 2014 | Samsung Microwave Ovens
    Gunge in door seal samsung Q1233 washing machine
    It's caused by using too much soap powder or fabric conditioner,it doesn't get rinsed away properly and goes greasy & slimy,,,,,if its starting too smell change door seal,,,,,use bicarbonate of soda 1 or 2 times a month, no clothes or detergent,& on a 90 degree wash,,,that should stop it returning
    Jun 19, 2013 | Washing Machines
    SE error code on Samsung dishwasher - ...any suggestions?
    This means that the Dishwashers has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the beeping sound, then try turning the Dishwashers off and on again.
    If you still see the "
    SE error code," turn off the power to your Dishwashers and wait five minutes before turning it on again. If you hear the beep or see the "SE error code" when you try to washing again, please call your authorized provider for service.
    Hope this help?.
    thanks for visit.
    Dec 15, 2010 | Samsung 24 in. DB3710D Dishwasher
    I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
    WATER DRAIN ERROR - Display shows 5E.
    5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
    Dec 11, 2010 | Samsung Washing Machines
    E8 error code
    8E - OVER CURRENT ERROR
    IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
    IPM: Integrated power module. The IPM controls the motor.
    If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
    If the motor stops working, in one direction ten times, "8E" Error is displayed.
    During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    May 02, 2009 | Washing Machines
    Samsung b1245s washing machine
    The error code HE2= water heater error (The heater element did not getting hot)
    Unplug the machine to reset this error.
    Try different cycle let see you still getting the same error.
    May 07, 2008 | Samsung WF337AA Front Load Washer
    Washing Machines Logo
    126 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
