Question about HP LaserJet 2420 Printer
How to clean the print head
Hi, I have an HP Laserjat 2300 that i use to make circtuit boards, recently i have noticed that there are spots in the middle of the images that are thin, but the outline are solid. I have noticed this kind of thing in an inkjet printer before, and fixed it by cleaning the print heads, is there any way that i can clean the head on this printer? Thank you in advance
  • brhsfnladvis Dec 08, 2008
    the image is not ghosting, there are just thin spots in the ink that dont get transfered when i copy them to the circuit board.
  • 138 Answers
The problem you are having is either the cartridge or fusing assembly. One or the other will need to be replaced. There isn't a head cleaning function on this laserjet like inkjets. Here's how you can tell which it is. If the image is ghost repeating, measure the distance from the first occurance on the page to the place (ghosting) it appears again. Here are the most common spacings.
Measurements are Aproximate
75mm or 2-15/16th" = Fuser (replace fusing assembly)
94mm or 3-11/16th" = Cartridge Drum (replace toner cartridge)
38mm 0r 1-1/2" = Cartridge Primary Charge Roller (replace toner cartridge)
Hope the above helps you. If so please rate my answer with a FIXYA. If not send me more info and I help you further. Thanks.
Posted on Dec 08, 2008
Copies of documents are not clear
Spots on copying: Chk is there any marks on flat bed glass?,clean flat bed glass with wet cotton cloth, allow it for dry.
Spots on printing: There is no particular reason for this issue. clean paper path with wet cotton cloth & allow for dry..
Mar 18, 2013 | HP Deskjet 2050 All-in-One Printer
Ink streaks
Ink streaks are usually caused by a buildup of died in on the print heads. There are two print heads in that unit. Remove one at a time and look for build up - clean it if you find any. Once you finish cleaning both print heads you will need to do a print head cleaning routine in the HP software to clear out any in clogging the print nozzles.
Oct 01, 2012 | HP Officejet 6500 Wireless All-in-One...
HP LASER JET 2300 52.00 ERROR
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
Sep 12, 2012 | HP LaserJet 2300 Printer
My C6280 was working fine then all at once it started to print very light. I have not got any error messages. I cleaned the printhead and it was pretty good on the first page I printed, the second page...
Hi.
The machine does not monitor the pressure of the ink. If there is a problem due to blockage of ink nozzles or defective print-head or cartridge it will not be detected by the main control. When instead the problem is the ink delivery system that transports ink from supply station to carriage print head, the problem will usually get spotted by main controller board and you get a "ink delivery system failure" error.
If the ink is fading is generally either cartridges or print-head. If you have already tested the cartridges by replacing them with cartridges from a different lot (make sure they are not refilled but new ones), then the problem is usually the print-head.
Cleaning the print-head with the option available in HP software will rarely help to solve this kind problem. You can try removing the whole ink carriage and soaking the part in isopropyl alcohol for about two day. The assembly is held to the rail and gets released using a gray tab on top back and disconnecting the cable at the back. Removal of the upper cover is usually needed. Printhead is HP part number 5069-7161.
Here the print head for this printer.
Here you can purchase parts and service manual for your printer.
Regards.
Ginko
Aug 08, 2011 | HP Photosmart C6280 Printer
Put new ink cartridge into my Lexmark 2300 and now it won't print
Make sure you remove the print head protective tape. Also try doing a head cleaning and cartridge alignment page. If it still does not print check the cartridge well, you will see a assortment of copper pint that contact the circuit tracing on the print head, with the printer off get some achohol and a Q-tip and clean the pins there may be ink residue on them.
May 25, 2010 | Office Equipment & Supplies
I refilled all cartridges and printheads and the red on documents does not print. What would the problem be?
goggled magenta print head
try printing a diagnostic page
after cleaning printheads from the menu
and then check if any printhead must be replaced
Oct 14, 2009 | HP Business Inkjet 2300 Thermal Printer
Quits printing magenta
Sounds like the printhead is kaput.
Jan 27, 2009 | HP DesignJet 100 InkJet Printer
TIMES PRINTER DOES NOT PRINT ,& OTHER TIMES ,IT IS BEAUTIFULL
you do not clean the heads on a HP printer the heads are on the print cartridge. You can run a 'cleaning cycle' if you have noticed your prints loosing some quality.
Dec 01, 2008 | HP Deskjet D1341 InkJet Printer
Lines on printed photos
Hi Have you tried cleaning the printer and doing a alignment for the inkjets? I believe under your printer properties you should have the option do to maintenance clean and alignment>when doing this it will use some ink but in order for the printer to function properly you sometimes have to do this. Hi hope this helps you!!
Dec 04, 2007 | Office Equipment & Supplies
HP LaserJet 2420 Printer Logo
590 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
